Kindness & Compassion
Remember guys, if you're up to it...
A donation tin for Bowel Cancer Aust will be on deck to receive any $$$ you can spare!
The tin will then be passed to NYTSKY (Dave) a long standing Member of SAU.NSW and his partner Anneke to help with Bowel Cancer Research.
Many Thanks In Advance For Your Grace!
  • Like 2
I can take people in but not back to penrith
Hi Jason,
Thanks for that. Flight# 740iL will contain 5x
Perhaps 1x will enjoy your passenger seat more than the Bimmer's rear jump seat on the way to Riverwood ;)
C U at Kendall St say at 12.35
Hi Jason,
No worries terry see you soon
Thanks to Theo for putting this on and to Terry for organising.
Here are some photos.
14170654423_9e648cd6d6_b.jpgDSC_0003 by Crashdown55, on Flickr
13963921467_ef5dd98f9a_b.jpgDSC_0005 by Crashdown55, on Flickr
14150609085_0b77f4ac64_b.jpgDSC_0006 by Crashdown55, on Flickr
13963918467_21a6b6e614_b.jpgDSC_0008 by Crashdown55, on Flickr
14170648313_28981125c3_b.jpgDSC_0009 by Crashdown55, on Flickr
14150605405_7b9675a102_b.jpgDSC_0010 by Crashdown55, on Flickr
14150603735_865011d845_b.jpgDSC_0012 by Crashdown55, on Flickr
13963954158_ed61df2b8b_b.jpgDSC_0015 by Crashdown55, on Flickr
13963953168_788f08df0b_b.jpgDSC_0016 by Crashdown55, on Flickr
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
