I know this topic’s been covered and seems to be an ‘Achilles Heel’ for the M35 but can someone please help me out with a query I have on this?
My question is, when I perform this procedure (Accelerator Pedal Released Position Learning , Throttle Valve Closed Position Learning , Idle Air Volume Learning ), must the AFM be plugged in or can I successfully perform this relearn with the Air Flow Meter unplugged and then plug it in once successfully performed?
Here’s my reasons for this:
Sunday afternoon, driving in the city 50kms the car splutters, slows and stalls.
Tried to restart it – starts but very low revs in idle, black smoke, stalls when put in gear.
I unplugged the AFM – car starts, idles and drives although very poorly but enough to limp home.
Got home – plugged in a spare AFM – same issue therefore it appears the next step in diagnosing issue is the reset procedure.
Thanks in advance for your insights
Ahh, something isn't right, and no amount of throttle re-learn will fix it. Have you done the flashy light dance?
My guess, if it indeed isn't the AFM, probably a big boost leak. Do you have the ability to make a plug for the intake and pressurise it to check for leaks?
Thanks Scotty,
I took the car to Craig at the weekend and after he plugged the laptop in we got the 'cam shaft sensor' code.
I went to Nissan, bought both sensors for the better part of $400 and after much fiddling was able to replace both of them. I also installed a new AFM, started her up and same problem. Stalls when the AFM is plugged in but will run sluggishly with it unplugged.
Is there something I've missed? the sensors were installed the correct way. What would you do next???
Toby
Hi Scott
I've got 2 new AFM's 1 Nissan one from Jetwreck. same issue.
I havn't done what you suggested - I don't kno whow to do this.
Do I need to relearn the AFM, etc after I replaced the two camshaft sensors?
Toby
No, you need to pressure test the piping, can you make a bung to fit the intake and get some pressure into it? 20psi works well if it will hold it.
Perhaps I should start making them, or hire my boost leak tester out...
I will call Craig and speak to him about it when I get a chance.
Hi Scotty
Thanks for this advise and the car is now in the hands of my mechanic however I will advise him to pressure test the piping. We have changed all 3 sensors, reset and it still has this issue. Is there anything else can tell him? Is it the intake that he must bung off to perform this test? I really appreciate your help
Yep, The intake, after the afm and before the turbo. It's an easy way to see if a pipe has split, it can be impossible to find otherwise.
Have him check the fuel pressure if possible. Should be around 35-40psi at idle.
If that doesn't fix it, all I can suggest is one of my AFM's, the Nissan ones are crap.
Hi Scotty
Thanks Scotty that was spot on. Asked my mechanic to pressure test and sure enough the intercooler piping had split. All fixed now and I've got your AFM fitted thanks to Craig and 2 new cam sensors which I didn't need but handy to know they're new.
Have a good long weekend
Toby
  • Like 1
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
