Hey Ciaron thanks for posting some meet up details. Will see you there from 6.
Also to those that ate coming I might suggest bringing an umbrella, chair and maybe picnic mat.
Be sure and wear you SAU gear if you have it cause we are representing the club.
See you all there. Should be a great
day out.
Being such kind folk...
Should we bring along tools for WRX,EVO and other teams to use like Made In China SAE sockets with hairline cracks, jack stands with small feet that'll readily sink in soft wet soil, sun-damaged cable ties, pre-cross-cut gaffa tape etc?
I haven't felt so mole-like since I was in HS.
day out.
AND dont forget to mention you are supporting SAU at the gates for free entry :yes:
Wow Terry you really are an evil man............................... I like your style!!!
You do know you have an Evo right?
This is what happen to the last Evo owner Terry gave some tools too....
I've picked the Esky & drinks from the trailer, but I'm not sure if Ill be able to make it up on the day.
Cans are packed in a plastic tub & a milk crate; esky is empty, clean & dry.
If I can't make it, I can drop everything around to Terry, & he may be able to take it up?
I'll see tonight/early tomorrow if I can make it; would really like to be there. :/
We would like you to be there too ;)
If it fits in the EVO, I can take it. If...
Matt may not be able to make it. If not > Car pool?
Desmond, NULON approached several car clubs - initially the Execs - asking if that respective car club would be willing to pit itself with 'their finest' against 'the finest' of other clubs.
In this case, their are three modules put forward by NULON.
1) Hillclimb
2) Drags
3) Track
If you join up as a Member, you can learn about other events too. A new Members' forum opens up to you.
this is our finest?
struth!
  • Like 1
1) Hillclimb
2) Drags
3) Track
Very nice! Actually i have joined up and paid about 2 weeks ago - but Shell is about to be Mummy so no rush =)
I used to do quite a bit of Autocrossing and Time Attacks in Malaysia previously and clock pretty good times in Sepang International Circuit with a Tuned Starlet Turbo..
I have been contemplating and also thinking about looking at competing again - for fun - Finally got a GTR in my life and i really would like to see how she runs and how it is when she runs hard... In Malaysia it would be a lot easier for me... i know quite a few nice driving roads and i used to go weekly - in NSW i dont know as i only just moved over permanently last September... Been going to Galston Gorge for some drives, but just to familiarize the GTR a bit, i live about 10 min away.
So yeah... will be nice to give it a try and have some nice runs... hence the curiosity.. lol
Thanks for replying so quickly guys!
That's good!
See you soon for our next Texi & Track Events when they're posted :)
I actually cant wait... the GTR is very different from all the other cars i have competed with in Malaysia.. very... LOL but yeah - learning curve, always a learning curve...
Just a quick question - what are the requirements to compete in a competition like this? These kind of hillclimbs or even Autocrossing in NSW / Australia? Just would like to understand more.
Hey mate, once you get into the super secret member's section, there is a club club motorsport thread to check out. This particular event is a little different, but generally hillclimbs are regular, accessible, and excellent fun :)
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
