Being such kind folk...
Should we bring along tools for WRX,EVO and other teams to use like Made In China SAE sockets with hairline cracks, jack stands with small feet that'll readily sink in soft wet soil, sun-damaged cable ties, pre-cross-cut gaffa tape etc?
I haven't felt so mole-like since I was in HS.
lol terry i hope we are never on opposite teams. :laugh:
Hey mate, once you get into the super secret member's section, there is a club club motorsport thread to check out. This particular event is a little different, but generally hillclimbs are regular, accessible, and excellent fun :)
Now that sounds like a brilliant plan!
Thanks to everyone for heading up to support the club team today.
It was a great event, shame it finished a bit early due to the big storm. Lots of quick cars although some of the fancy time attack did not end up at the pointy end of the field.
1st was heafy's evo, 2nd fernance evo, 3rd mckinnon.
Our guys came home:
Nick 8th 41.24
Brian 11th 42.32
Matt 30th 46.63
Me 32nd 46.75
Maurice 41st 51.38
Well done for everyone giving it a go in tricky conditions, and from me particular thanks to Neil for handing over Cheryl's keys when I couldn't get ready in time.
And most of all, good on Nulon for putting this event together, looking forward to the next round at wake on 4 July
Big thanks for Nulon for putting the event on, shame I never got a quick dry run, my very first run in the dry was the quickest while still finding where the road went, next two run had a wet track which was a bugger, But ready to go for next year now I know the track :)
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
