I have BMI DVD at home where S2000, WRX, RX8, V35, Integra R, and MX5 race around Tskuba(sp)... all cars are stock and the S2000 wins by a hair over the V35 Skyline. The WRX is third with its brakes fading, and the Integra R is 4th followed by the RX8 and then a country mile back to the MX5 in last place.
The V35 is very impressive coming from last place through the field to almost past the S2000 which had bolted at the start... one more lap and he would have got him... the RX8 handles well but not enough grunt... the V35 out handles them all!!!
https://www.sau.com.au/forums/topic/44135-g35v35-videos/#findComment-903173
yep, i downloaded this clip. i'll have a search around for the dl later for you guys
https://www.sau.com.au/forums/topic/44135-g35v35-videos/#findComment-903753
plan on taking some amutur vids in the near future, but i'll have to get them hosted? took one the week end to test my new camcorder and bracket i made... just of the speedo on a 0-60 launch. I was on a public road so just did the one.
On replay I timed 4.9 secs. maybe not the most scientific/acurate but it proved one thing.... I need to practice my technique :);)
https://www.sau.com.au/forums/topic/44135-g35v35-videos/#findComment-903819
ask christian if you can host them on sau, if they're not too big.
edit: i found the video on my puter. the name of the file is ' g35zm3 '. it's 79mb. cannot find the original place i got it from but search google with the name and you'll see places to dl.
https://www.sau.com.au/forums/topic/44135-g35v35-videos/#findComment-903912
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
