Fairly new to skylines as ive only had my r33 for about a month. I want to have a crack at drift but the stock viscous lsd is very loose and unpredictable. I've done a bit of research and from what I've read the viscous lsds aren't worth wasting money on (correct me if I'm wrong).
So what are my best value for money options considering the car will still be driven on the road from time to time. ( I have no interest in welding my diff I'd rather do it right and do it once)
- Buy an new aftermarket lsd such as kaaz, nismo, cusco (expensive. Are they worth the money?)
-buy a second hand diff with aftermarket lsd installed from an importer. ( a little less expensive and lsd is already installed but worried I will get one that's worn out and needs rebuilding which could get costly)
- from what I have read Gtrs had a mechanical 2 way that works well when shimmed/rebuilt will these fit in a gtst how much work is involved and what kind of money would this set me back.
Any advice from someone with experience would be greatly appreciated.
https://www.sau.com.au/forums/topic/441360-r33-gtst-lsd-diff-options/
Lots of guys into drift run a 2 way but either will suit your purposes really. All of the above-mentioned brands would be fine as they are tried and tested. Kaaz have good support and make all the clutches etc. available for rebuild if it becomes worn out down the track, unsure about availability of the others.
As above, most drift guys will likely run a 2 way over a 1.5 way.
I bought my Kaaz 1.5 way diff centre second hand from Yahoo auctions Japan and had it shipped over through Jesse Streeter. I think the 2 way diffs were even less as there were more around than the 1.5 ways when I was looking.
Cost me a bit less than $500 delivered. Had it refurb'd and reshimmed locally, then installed into my existing diff housing. Cost me around $1000 by the time it was in my car.
Diff is super tight and haven't looked back!
Best option is R34 helical. Found on later model coupe GTT only R34 manual. Good luck !
Won't need rebuilt, better street diff than clutch-type but not as good for 100% balls-out lifted wheel action on a track.
My mechanical is noisy. It makes the inside wheel skip and chatter on turns, and gives the car a good shake when cold.
It's not a daily driver though so I don't mind it.
Throw in OS GIKEN 80W-250. Calmed down my GT Pro by 90%.
Add limslip or use Nulon SAE90 GL5 oil. Mines pretty good and you don't even notice it half the time.
    • Yep, replacing all those hoses is kind of just bog standard if you're ever back there. Only hose on the back of the engine I have yet to replace is a vacuum hose for the wastegate. I'll probably do it eventually but it's in such an annoying spot.
    • I was actually just planning on replacing the fourth gear parts in the gear box that I broke … like the synchro hub or cone. And any other parts I need once I open up the transmission. That a bad idea? The rest of the gears feel tight. these parts shouldn’t be too much … just the labour here won’t be cheap. Just replacing these in HK would be around 2k aud including labour.    how much is a new r33 or r32 transmission?    thanks for the good info as usual
    • I chose a bad time to buy, at the time there was no gtst's for sale in NSW and my options were qld, vic, or sa and not the greatest examples or too far out of my budget. Ended up picking this one from adelaide sight unseen and got a bit stitched up as you could expect but i dont fully regret it, its just a shame people cant be more transparent in this day and age.
    • IMO just buy a whole R33 transmission and swap the whole thing. Use a palm nailer/air hammer with a roll pin punch to drive the shifter rod end roll pins out. The rod end is discontinued so don't break it. Use gasket dressing on the OEM paper gasket instead of RTV. I personally would not pry on the shifter cover tabs, I broke one trying that instead of just smacking the side with a dead blow rubber mallet to shock it loose from the RTV the last mechanic applied. If you can't get the flanges totally clean and free of any residual RTV and/or you might have a gap that is bigger than it should due to flange damage use RTV on that surface instead of the OEM specced anaerobic sealer. Anaerobic sealer is most likely the right sealant for the job, it's just too easy to mess it up with too large a gap or bad surface prep/roughness seemingly. If you do rebuild what you have it's for a whole gearset that can take high torque. Don't bother with OEM at that point.
    • Little hose. Big hose. They're all waiting to kill the engine.
