Man if its only temporary, i'd suggest an APEXI SAFC.....Yes yes i know they are old tech but they work very well for stock/mild cars and are mega cheap these days. $100 for an SAFC and $150 to tune it you could run your highflow and even up the boost a tad, then when you get some extra cash you can always get your money back for the SAFC. Just a thought.
  On 01/04/2014 at 10:25 PM, GTScotT said:
This could be read as it is safe to run 22psi on the stock ecu with a highflow, which is very wrong.
Please fix your post so we keep everything accurate.
What is the correct maximum amount of boost you have safely run on a stock ECU with a highflow?
yep thats how i read it
  On 01/04/2014 at 10:54 PM, skidlineTodd said:
how would the car perform with the highflow turbo and no tune?
I will post a photo of my turbo for more understanding haha
why highlow, just get rebuilt turbo....with wheels that dont self destruct
  On 02/04/2014 at 12:48 AM, Leroy Peterson said:
Old turbo died and took out motor... coin spent on new motor, ideally wants more power, but doesnt want to spend more money... hmmmmmmm
I would rather spend $900 on a cheap nistune + tune than getting a different turbo for "reliability".
This sounds like good advice.
no nistune option is cheap for an r33....if you dont know this already you do now, so you can stop giving crappy advice :P
SAFC can only bend the AFRs, however it does not change timing.. if you look at the stock R33 map, timing values are around 22 on noise, which is heaps if you decent to add in more boost.
Like I said, best option is a Toshi remap.. happy days pump nearly 1 bar into motor no knock, and happy AFRs
oh ok. thought it'd just be like a daughter board or something... pulsar ftw
yeah its a daughter board and a z32 ecu and a separate VCT switch and just a whole lotta assing about in general...
The SAFC doesn't bend AFR's, it bends the Airflow meter signal, which in turn causes the ECU to reference different cells(Fuel AND Timing) than it would without the AFC.....plus i only recommended it as a cheap alternative till he sorts out a proper ECU ;)
Yeah I know what you mean, I just said AFR because bending the AFM signals causes the AFRs to change.
However you do realise that will cause the ECU to reference cells with less load = more timing right?
Ofcourse, however in the last few 33's i've installed these into drive great and do not ping at 11-12PSI(11.5-ish AFR)
Edited by Super Drager
its all good! going R + R is good motivation to get the ECU upgraded.
I admit making an mistake quoting the maximum boost level safe to run on stock ecu earlier. Been corrected and that it should be no higher then 10psi.
Reason of having the high flow, as cost wise is similar or cheaper then to rebuild, similar drive ability working with factory ecu, making good power when other supporting mods are present, and proven by time to last.
For a budget ECU upgrade you can get Toshi to remap based on factory injectors and AFM. I've personally sent few customers that direction and worked well.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 馃槑
    • Cool, I鈥檓 just down Sydney today. Not much time to get online.
