Hi guys
I'm new on this forum, hope starting this topic in right place :)
I recently cleaned throttle body and intake collector. doing this I accidentaly made puncture on EGR temp sensor's coolant hose. I found it out later, drove for one day :( I fixed the puncture, but check engine came out . I scanned my car at local dealer's shop, p1401 faulty code "EGR Temp sen/circ" came out. I tried to reset ECU, but did not solved my problem, after 3-4 km driving check engine is coming again.
Is there any chance to fix it?
You damaged the temp sensor. No big deal, you ca either replace the sensor or trick the ecu into thinking it is still in the circuit with a similar resistance soldered over it's wires.
Before you go further, can you make sure the temp sensor is plugged in properly? It's behind the plenum and throttle, thin white wire.
  • Like 1
maybe is's overheated because of coolant leakage :( I know it is not big deal, I hate this sensor, it makes intake collector dirty :)
I checked it and connection is ok. How can I trick the ECU? which exact tips to solder?
Did you block the egr? If so you will need to put a resistor over the temp probe to get rid of the MIL.
Otherwise something is wrong with the temp sensor or the wires that connect it to the ecu. Did you forget to plug the temp sensor back in?
If I may, i have one more question:
My friend's 2005 250gt has problems with RPM, they are unstable. We resetted ecu several times and made idle air flow learning. Sometimes when he drives and turns gear to N rpms goes up to 1200-1500 and after switching to D gearbox is kicking hard :(
we checked on scanner and there are no ongoing faulty codes.
What can be the cause of this jumping rpms?
Edited by geoskyline
Did someone clean the throttle? Check all the vac lines are connected and not leaking.
You will probably need to do a throttle re-learn.
nope, nobody has done throttle body clean. I know what you mean, but this RPM jumping occurs occasionally, not always.
Something is letting excess air into the plenum occasionally, perhaps the egr valve is sticking open due to crud?
obviously the problem is mechanical not electrical. If problem would be electrical it should cam up on scanner :(
when my friend bought the car he fixed the loosen chain. is it possible mechanic did not fixed it properly, as i know chain has a mark points to sync it to engine.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
