Rb25De '95 R33 Intake Questions
Was just wondering if you could help me out..
ive done about an hours research and still fairly clouded
there is a what i will call "air reservoir" half way up the intake pipe
that runs from the airbox to the intake mani..
and there isnt much distant between this box and my extractors
it has melted the bottom of this air reservoir and stuffing out my
revs/time as its bringing air in after the oxygen sensor..
and what i wanted to ask is am i able to eliminate this box all together
i believe the on hose plumbed to this box is idle air maybe..
what to do with this so i never get this issue...
sorry if i sound derp haha.. this has just done my head in
its a pain in the backside
Edited by hazeR33
Its bringing in air after the afm but BEFORE your O2 sensor. . .to answer your question i believe the part you are describing is (you have pics?) is a resonance chamber , you should be able to replace it with a hardpipe no worries
there is a pic in my original post man..
i was thinking of just replumbing the idle air hose
from the resonance box straight to the intake pipe
with maybe a one way valve attached.
cause i think its just a throttle body bypass for idle air
is this resonance box shaped and made in a certain way for
any reason?
when i removed the hose from the box..
put a sock over it just to test free air sucking
because the intake pipe will allow a bigger air flow
and my car just either stalling or idles rough as guts
is that just a matter of playing with idle revs and/or timing?
i ended up cutting the box off with an angle grinder fibreglassing
the pipe.. then sikaflexing under the fibreglass.. and then coated
the whole lot in black sika just to ease paranoia.. then cut the nipple
for the hose.. did the same.. and left it all over night.. and she runs sweet
makes an awesome induction rumble haha
also did a fair service as in plugs, oil, filters flushed it all.. runs beautifullyy
and heres a pic of what i did lol
 Share
    • Not much info in that request..... If you have a VIN you could look up the factory part number here: https://www.amayama.com/en/genuine-catalogs/nissan
    • 2.5 torque? 3.0 torque? Pft. Dude the van is right there. Consolidate your projects, put the LS into the R32 and have either a R32 with grunt, or a firebird that handles, however you want to refer to it. Either way you won't want to drive the Firebird or a RB powered Skyline ever again so this is the proper solution, and you cut down on projects. It makes sense even if you hate it.
    • Never mind the ash - the massive witness mark on the leading edge of the rear arch make little baby jesus cry.
    • Some small fixes made over the weekend. I've been trying to get the car sitting right on the 275's as well as reducing the rubbing as much as possible. I bought a guard roller but the lip within the guard is obviously made of high tensile steel because it took so much work and heat to get the smallest of movements that I totally flared my rear arches. It looks kinda cool.   I also got inside the arches with a dremel to cut down the bumper and the bumper mounts. The first one (pictured) got a bit ugly but the next one was much nicer as I just cut slots and hammered them upwards. I gave it all a spray of primer too. I'm still scrubbing a little bit on passenger side but it has less camber than the drivers, so once that is sorted it *should* be ok. I drop a single corner down on the ramp to simulate that mismatch and see where it is scrubbing.         Here's my flares. The car is lower than this now. Excuse the bush fire ash on the car.    I also haven't had windscreen washer jets for weeks so thought I'd tackle that. It looks like a leak is coming from under the headlight. Just in there. See it?  This would have been clearer and easier if I'd taken the front bar off, but basically the plastic hose connector has broken off the headlight sprayer. And because I couldn't be arsed taking the bar off and fixing what is already a gimmick, I just disconnected the feed hose and with some aquarium hose, circlamps and a drive shaft bolt I fixed it good. The hex piece I tried first did not seal too well (2nd pic) - not sure why I thought it would! 🤦‍♂️.   Because I hate things being broken, I will fix this, but until I could be bothered to take my bar off, this will suffice. Note the BMW push-in hose connector. Because standardised fittings are too passé. I now have an issue with my adaptive headlights always pointing too low and sometimes shaking back and forth when I'm driving. I'm keen to have these working properly. On another note, I bought a set of EBC BlueStuff for the front. I looked at so many reviews; DBA Xtreme (not enough reviews), Ferodo DS2500 (Super expensive and hard to find), Hawk HP+ (hard to find, not many track/street combo reviews) and some others. Was able to get the Blues pretty cheap (~$250 delivered). Also there's a motorsport joint in Hornsby that will supply and install a RacingDiffs LSD conversion for $850 which is pretty good. I know its not a proper LSD but I'm just not keen right now to spend $3500+ on a proper one. I figure I'll give this a go and see what its like, if nothing breaks I can sell the diff with this in and upgrade later if I want. There are some streets near me I cannot get up in the wet at all and just spin a lot in the dry, it would be nice to have traction on these. (I live on a big hill). My first ever skid pan is coming up on the 8th of Nov. Can't believe I've never done one. Really looking forward to it.
    • He hasn't been seen here since the day of the above post.
