hey everyone just figured id post up my project thus far.
1999 R34 GTT RB25det Neo
when i got the car is had GTR items swapped for that gtr look on exterior. (hood, bumpersn side skirts) still looking to change out front fenders and do the over quarters to finish the body conversion.
I have also decided to do the RB26 swap. keep it RWD for this summer until i can locate proper front end parts to do the AWD swap (projected to under go that next winter)
i know this project is expensive and alot of people will say why not just buy a real GTR but being from the US an R34 GT-R is almost impossible to locate. there are only a few authentic R34 GT-Rs in the us. even the R34 GTT is pretty rare find. that being said lets not make this and arguement thread on GTT and GTRs. :)
I purchased an R32 RB26dett and AWD trans (both from R32 GT-R) i really wanted the R32 trans so i can make it selectable 2wd 4wd. the motor from the R32 and R33 also tends to be alot more affordable here in the states. and plus i plan to do full internal build next winter so i didnt see any benefits spending twice as much on the R34 GTR motor/trans. I also have an R33 RB25det and rwd trans sitting in shop that is for my 93 240sx but im going to put that on the back burner for a while and rob needed parts off that set up to make the R34 project move a bit more swiftly.
so in the shop we have an R34 GTT with RB25det Neo/Rwd trans, RB25det from R33 w/Rwd trans, RB26dett w/Awd trans from R32. all of which have full wire harnesses and ECUs (R33 motor also has greddy Emanage Ultimate computer with greddy harness kit to plug it in)
the plan:
RB26dett R32 motor, R33 RWD trans, use motor mounts from NEO to fit the RB26 in the R34.
Current status:
R34 Neo motor is ready to come out, RB26 in on engine stand (i freshened her up a bit and fitted a few goodies on it)
PROBLEM:
Wiring!!!!!!! the Harness for the Neo in the R34 is very complex, and also seems to have alot of "body control" features tied into it.
I have seen a few people do the RB26 swap in the R34s. what do they do for harness, ECU and keeping the creature comforts in the R34???? any and all help is needed!
https://www.sau.com.au/forums/topic/441459-r34-gtt-rb26-swap/
ok so i made a list of wires i cut to separate the body harness from engine harness
What i am calling the "body harness" is the harness that splits off at the fire wall right after it comes to engine bay, it immediately has plugs that hook up the the ABS system then the rest of the loom travels along the left inner fender then across the core/radiator support to fuse box. Im assuming that i need that part of harness to stay with the car.
the "engine harness" is what travels along fire wall to the motor.
i also self named some of the plugs or mini looms/harnesses that branch off 1-4. i will psot a pic of each mini harn or plug with a label to help make sense of this.
cut wires on NEO harness to ECU.pdf
Other wires cut from R34 GTT harnesses.pdf
Not sure if the 25 sump will go on a 26 mate pretty sure u need custom fab sump and just so you know when u get to it the 32 speedo is mechanically driven nd 34 is electronic so u will need to do the speedo cable modification you are better off just skipping the 33 box nd doing it properly so u dont need to fab a sump u dont need
I have heavily dissected many R34 GTT harnesses across several cars and could probably wire one with my eyes closed. I have modded my Auto GTT harness to remove all the auto related wiring, removed traction control wiring, removed unneeded factory sensors and added in extra wiring for Oil pressure, fuel pressure and MAP sensor wiring, all while retaining ABS and it clips up to my RB26/30 as if it was stock. I run a Haltech R34 GTT plugin ECU.
I have spliced an R34 25GT (non turbo) harness with a GTT harness so it was a plug in job for my girlfriends R34 that we swapped a GTT motor into. The 25GT's have a separate ABS computer and harness which I had to move into the GTT harness while removing the existing GTT ABS/TCS wiring from it.
I have a pinout guide including a diagram of the large 'M53' or 'F3' plug (your 'plug 2') here: http://www.skylinesaustralia.com/forums/topic/420680-definitive-r34-gtt-wiring-pinouts/
Disregard wire color when tracing between plugs. Nissan used same coloring between devices so don't rely on this to be sure where a wire goes. There are splices and joins in wires inside harnesses also, so dont chop anything out because it may be supplying a signal to more than one other wire.
Your 'Plug 1' - ABS and traction control related. The red/green twisted wires is front left wheel speed. The grey 3 core is the electric TCS butterfly position sensor wiring (i think, going off memory here). You'll need to keep most signals going to this plug if you want to retain ABS etc.
Your 'Plug 2' - See my spreadsheet in the link above..
Your 'Harness 3' - ECCS and TCS relays. Brown is ECCS relay, this is an ECU controlled relay that powers everything up. It allows the ECU to shut everything down ifrequired. Blue is the throttle motor relay from memory.
Your 'Harness 4' - TCS Throttle control box. This takes signals from the ABS/TCS ECU in the boot via your 'Plug 1' and also the ECU.
My overall advice.. stay 2wd. Going 4wd later on will require a complete mechanical and electrical overhaul of the entire car. Chassis needs to be cut to allow for front driveshafts, you'll need to source an entire 34gtr front K frame, all of the atessa systems etc. Totally not worth it, just buy a 34GTR somehow.
Converting the car to run the rb26 as 2wd is much easier. You'll need to have the sump modified to remove the diff and possibly notched so it clears the front swaybar. Use the GTT engine mounts and it will bolt right in.
For electronics I would get a plug in fully programmable R34 GTT ECU, and run it with the stock GTT harness and sensors with the bits removed you don't need. This is exactly how I run my setup and it is flawless.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
