Event:
SAU vs QEO Super Sprints at Queensland Raceway
Description:
This is our second sprint day for the year and this time we're upping the ante! We have invited along the Queensland Evo Owners for a bit of a competition. The format will be 10 v 10.
This is a full track day.
There will be practice laps from 8:30 am through 11:30 am.
We will then have a break for lunch.
At 12:00, we will be briefed and then onto the track for our laps.
Queensland Raceway
Date:
Saturday the 7th of June 2014
Time:
Be there by 8:00am for a 8:45am start.
Cost:
$145 for members
$175 for non-members
You will need a timing chip which can be either bought from QR or rented for the day. They cost $80 to purchase and can be used at any timed event held by QR. You can rent them for $20 for the day with a $60 deposit which will be returned to you at the end of the day. You will also need to hold or purchase a racing licence from QR.
There are only 10 spots available!
From today until the 7th of May we will be releasing the event to members only on a first in best dressed basis, after this date we will open the remaining spots to anyone. If you reserve a spot but haven't paid and submitted your entry form by the 16th of May your spot is fair game.
So if you want to guarantee a spot get in quick.
If all 10 spots are taken we will start a reserve list of people to take anyone's place if they have to pull out for any reason.
Requirements:
  • Completed Entry Form and Money paid by due date.
  • Helmet
  • Timing Chip
  • ABS & SRS systems may be disconnected at the driver's option
  • Drivers must wear non-flammable clothing that fully covers the body from ankle to wrist to neck
  • If vehicle is road registered or road registerable must meet the roadworthy requirements of Qld Transport
  • If vehicle is not road registerable it must meet the applicable Racing Car standards below
  • Fire extinguishers, when fitted, must meet AS1841 standard and be secured to ensure they cannot injure the driver in the
  • event of an accident.
  • Tyres must be fit for purpose, not recut or retreaded, and be fitted to rim widths that comply with the Tyre and Rim
  • Association manual and/or ADR requirements
  • Rear facing red lights for use during rain must be fitted.
Can everyine coming please fill out the form HERE, you have to create a login account and purchase a licence for this year (if you don't already have one) then select the SAU event on the 07-06-2014. They need you to give credit card details but the page says no money will be charged to you as the session has already been paid for. Could everyone who is confirmed as coming please fill this form out.
Payment Details:
Name: Skylines Australia Queensland Club
Bank: Westpac
BSB: 034 063
ACC: 354012
PAYMENT REFERENCE: Username&Sprint
https://www.sau.com.au/forums/topic/441485-sau-vs-qeo-qr-sprint-day-07-06-14/
First!
Attendees:
1. Cadmoon
2. Sick_R31 Paid
3. CourtoR33 Paid
4. phillsutty Paid
5. HiveFleetAbyss Paid
6. wolfman101 Paid
7. Kolossus Paid
8. FineLine
9. Smity42
10. Dan Reardon (Evo VIII) Paid
11. Adam McLeod (Evo X) Paid
12. Alex Bradford (Evo IX) Paid
13. Jackson Madders (Evo X) Paid
14. Rob Ernst (Evo VIII) Paid
15. Emily Flemming (Evo IV) Paid
16. Sarah Lawson (evo VIII) Paid
17. Paul Tme (Evo VI) Paid
18. Dan Rule (R33 GTS25T) Paid
19. Ben Duncan (Evo IX) Paid
20. Benjamin Williams (Evo VII) Paid
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
