Question:
Do you figure I could pay once, but take 2 different cars out? Assuming Boz would drive one of course.
I'm not sure what QR's rules on that would be, I believe they only allow 1 car per driver.
I thought that it was the other way around. 1 driver can have a few cars, but additional drivers need to pay. McFly had the pinny and the wedge out last time IIRC.
That was lakeside. Not sure how that worked. I drive one out and he drove the other. Time permitting I may come watch.
I'm defs in mike will get the money in no later the 1 week beforehand.
Also where are the forms that we have to fill out?
HERE Zeke, you have to create a login account and purchase a licence for this year (if you don't already have one) then select the SAU event on the 07-06-2014. They need you to give credit card details but the page says no money will be charged to you as the session has already been paid for. Could everyone who is confirmed as coming please fill this form out.
Also Carl from the Evo guys has people to fill our remaining spots so anyone who is thinking about coming make up your mind ASAP.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
