Hi I got for sale
A high flowed s14 t28 turbo off hypergear to atr28g2 specs so complete bolt on for s13/4/15 or 180sx sr20det
Excellent cond no leaks minimal shaftplay 1bar actuator
proberly 15000kms old also has a fnt .64 rear housing by hypergear to help spool less than 5000kms old and he checked the turbo out when he fitted its and said it's was excellent cond still
made 251.9rwkw on 25psi to 21psi taper 20psi by 3650rpm and went 12.4@120mph on 20psi so those after a responsive 250kw and bolt on upgrade at the price of a t28bb this is for you kills a kando td05h18g or t518z as seen in the dyno sheet comparison in power and response
Price $550
Located Sydney west mt Druitt area
Contact pm me
Selling due to upgrade to hypergears new atr28ss.15 billet turbo
post-79144-1396625343381_thumb.jpgpost-79144-13966253605126_thumb.jpgpost-79144-13966253773578_thumb.jpg
https://www.sau.com.au/forums/topic/441503-t28-hi-flowed-by-hypergear-atr28g2/
Its coming back for a trade of a bigger turbocharger. So still for sale. Any one interested let me know. $500 with 12 month warranty. SMS my self or call 0413457185 if interested.
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
