Hi,
Is the GT2835Kai still a good option these days or has it been super-seeded by newer designs?
What power output is reasonable to expect with that turbo?
I currently have a non ball bearing hybrid making 260KW at the wheels.
(on RB25)
So I am remotely thinking about an upgrade to get me into the 300KW region.
Would that be realistic with the GT2835Kai?
Thanks ..
https://www.sau.com.au/forums/topic/441505-hks-gt2835kai-still-a-good-option/
A GT2835 KAI would be good if you can find a 2835 Pro S turbine housing for it .
In T3 flange and IW from Garrett their GTX3067R is rated at 500 crank horsepower , no ones tried one AFAIK on an RB25 yet and is possibly similar power wise to a GT2835 Pro S 0.68 AR .
GT3076Rs are tried and proven 300+ RWKW if the engine and exhaust is up to it .
A .
Thanks for the feedback.
The easiest option for me is a drop in replacement since this is what I have right now.
So I wanted to know if the KAI would get me towards 300KW.
Going E85 is not really an option since the car is used as daily ride and E85 is not that common in the UK.
Of course I could throw in a bigger turbo on hi/low mount and make 300KW.
But that would constitute ripping my current set-up apart.
Yes, my car is set-up for 300KW (4 Inch / 3.5, Poncams, TomeiFuel Pump, 555 Injectors, Blitz FMIC etc.)
I am making the current 260KW at .9 BAR ! so the engine flows very well.
If your making 260kw @ less than 14psi, I'd be winding your existing turbo up to 20-22psi and seeing how close you get.
You'll need to run this sort of boost to crack 300 if you swapped out your turbo for those mentioned anyway looking at various results from others running 300+
Yes, but the engine outflows the hybrid-turbo so I can not up the boost.
In other terms:
The turbo can not deliver more flow and is running out of puff.
That's why I am looking into other turbo options.
I never investigated the wastegate but the actuator is set to one bar and the controller .5 bar higher.
The turbo is rated at around 400HP (based on what it can flow) and boost drops gradually since the turbo can not keep up with air demand from the engine.
You can see this on many dyno graphs that boost gradually drops and this is not due to the wastegate.
(though a blown open gate is always an option)
Boost is meaningless anyhow, it is the mass of air going into the engine which makes power (+ the fuel of course)
Still I will check on the WG but I think that is not the problem, I just need a bigger turbo :)
Believe me, if you can get a stronger spring on the gate the manifold will hold more pressure, meaning the turbo will spin faster and create more boost. This will usually make more power and always add torque.
More preload on the actuator doesn't work as well as a properly selected gate spring. Try and run as close to your desired boost as possible.
A bigger turbo comes with drawbacks. Not saying don't do it, but there are many ways to get more power without changing it.
In other terms:
If you can keep your wastegate closed longer you may make more boost. You say you need airflow not boost but to use your terminology when your boost gauge reads 20 psi that indicates that the turbo has caught up to the flow through the engine - you have no other way of measuring flow unless you have a read out from the maf.
Having said that it is possible that your turbo has indeed run out of puff but check the wastegate boost control first.
HI!
Misunderstanding:
I did not say I need more airflow not boost, but merely said that it's not boost which makes the power. (since people always say you need such and such boost levels for such and such power)
And of course If my boost goes up the airflow will increase.
I will check the actuator but it is an adjustable one and the preload (of the spring) is pretty heavy.
Btw:
I can read my MAF values (voltage) in real time through Nistune.
This is a direct representation of mass air flow (MAF)
Cheers
Thanks,
Yes, I don't want any more lag that's why I was investigating the ball bearing HKS.
At current I like my setup / engine response and worked long and hard to achieve this.
260KW at the wheels is not bad and the car is fun to drive.
I will check on the actuator just to be 100% certain.
But as said the Turbo is rated at 400HP and I think I simply reached that limit.
I think Simon's suggestion at post #2 made the most sense given the OP is in the UK and not running E85.
Looking at this thread, if the OP's setup consists of bolt-on airflow modifications only (inlet pipes, turbo, FMIC, poncams and exhaust), I'd suggest his dyno might be happier than the typical Australian spec. 260rwkW from 13psi on an RB25 is not something generally seen.
  • Like 2
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
