I think Simon's suggestion at post #2 made the most sense given the OP is in the UK and not running E85.
Looking at this thread, if the OP's setup consists of bolt-on airflow modifications only (inlet pipes, turbo, FMIC, poncams and exhaust), I'd suggest his dyno might be happier than the typical Australian spec. 260rwkW from 13psi on an RB25 is not something generally seen.
It's 252RKW (301KW crank) @ 6300 @ .9 BAR /13PSI
In the attached file you can see how boost creeps out.
My target pressure was 18PSI
Hmmm looks like there is a real issue there, exhaust/inlet restriction?
Mine held 18psi near perfect with the Power FC boost controller. I did have a few problems with the bost fluctuating up and down between 15-18psi pretty rapidly but ended up sorting that out.
Hello,
Was your Turbo the HKS Pro S?
Mine is just a Hybrid rated at 380HP.
If I set it to say 14PSI target the boost curve would be more linear
I guess I am just asking too much from a small turbo.
I could double check if the gate opens too early but have no high hopes.
Otherwise I see no restricting factors.
Blitz FMIC
HKS DUMP
Tomei 4'' downpipe / Pon Cams
HKS 3'5 exhaust
The kai will NOT go 300kw on petrol.. Probably Wouldn't make the power you have now. As earlier stated your best/only real option will be a GT30 if you wanna do 400hp on the tarmac ;)
Thanks,
GT30 would mean high mount / ext gate then ...(?)
Would need to do some research on that I guess.
If the KAI would do 280KW+ that would be enough for me but I think it is rated at about 400HP?
Making less power than I have is not really an option :)
The Pro S was a better turbo and despite all information to suggest that the KAI should be better it does not live up to they stats HKS post. I was disappointed as I originally ordered a PRO S and Nengun said it was discontinued and the KAI was better. So I eventually moved on to a hypergear turbo. Was frustrated with the lack of support from HKS who basically said the turbo wasn't making the power because of the tune or something that I'd done and after only 1 or 2 replies began to ignore my complaints
The KAI is not a bad turbo, im not going to say that at all, it's pretty great for a street car. However it doesn't produce the power of the old PRO S so as above don't expect it to go to 300rwkw, even on E85 I don't think you'd quite get there. The most I've heard of is about 260rwkw on a 25 neo with poncams
How happy are you with Hyper-Gear?
Spoolup should be somewhat worse compared to the HKS.
Here the PRO-S making 320KW on E85
http://www.skylinesaustralia.com/forums/topic/412682-300-rwkw-gtst-top-shelf-parts-only-price-drop-for-members/?hl=hks+pro
Joeyjoejoe....'s result is often quoted for the Pro S, but I think even he admitted it seemed to be freakishly good compared to others. More common was around 260rwkW, and a touch more with cams.
I've spent a lot of time trying to find a turbo like Pro S, but haven't got there yet. Shame the Kai wasn't a worthy successor. Also, by the way you can buy the Garrett equivalent of the Pro S, but the issue is trying to find a decent turbine housing.
We have to remember what was available when HKS put those GT Pro S turbos on the market - SFA . There were no Garrett IW GT30 turbine housings then so you were pretty much stuck with a Pro S or an external gate . Or some bastardised machined out dinosaur T3 IW housing .
If you can't rat up a Pro S turbine housing then you may need to look at the GTX3067Rs , we haven't seen one yet on an RB with the 0.63AR IW turbine housing but its worth consideration .
The 2835 KAI looks like a band aid for the Pro S version . It's basically taking a GTRS and putting a cropped GT30 turbine in it so the value is a slightly larger and heavier turbine in a T3 flanged GT28 0.64 AR turbine housing . It bolts straight up and takes the standard dump flange .
I personally reckon that if you can't get a Pro S housing and its unique dump pipe (or make the dump) you are better off with a GT30 based turbo even if it means using the smaller 0.63 turbine housing . Once your set up for the manifold spacer and GT30 IW dump pipe you open up a range of turbo options you don't get with much else .
Had Garrett had the GT30IW housings back in the day there probably wouldn't have been Pro S housings and dump pipes .
Also consider Hypergears turbos , cheers A .
Im more than happy with the hypergear so far. Stao's customer service is great and he is always updating which means you can send the turbo back to be upgraded for better performance. Also when it comes time to rebuild the turbo, I dare say a hypergear would be cheaper to rebuild. The main problem with the 2835 is the price. If it was resonably priced they would be good, but I think I payed about $3500 for my HKS turbo where as the hypergear cost under $2000. Fair enough the HKS turbo comes in a kit but it's not worth the extra money as far as im concerned
The big issue for me as well is customer support. As I already said, expect Zero of that if you go HKS where as at least hypergear is local and Stao is willing to discuss issues etc. Customer support probably isn't an issue with the HKS but for me when I originally ordered a pro s, and had seen so many pull around 280rwkw, to then have mine under perform that I was kinda after some answers. I was rather unlucky in my Situation as I would have been one of the first to get one of these so Nengun didn't know it would be worse then the Pro S so I couldn't really blame them for selling me what was essentially a super seeded part
@89CAL ->
That must have been a disappointment. Especially after investing quite a bit of $$.
Would you have dynos of the HKS vs / and the Hypergear?
Does the HG introduce more lag ? (it should)
What is your current power?
My turbo make 14.4 PSI (1BAR) at 3500 rpm.
That's the benchmark I compare against for spoolup.
Edited by Torques
Hello,
I was hoping that the bridge between low lag and high power could be drawn easier these days.
So billet wheels and ball bearing would be of my interest.
All things being equal the HKS is a bit aged now and is 'only' rated at about 410HP (CRANK) or so.
Back in the day that that was good power.
I would need to do more research on available turbo options and how well they spool up on RB25.
Making huge power is no so difficult but I need my car to be torque rich and responsive.
My current benchmark is 1 bar (14.4PSI) at 3500 RPM and the new turbo should be in that region while holding 16-18PSI at 6500RPM.
I once did the maths for this leading to the required compressor map.
I will revisit Hypergears turbos as well .. Stao has many options available.
Edited by Torques
Ignore it, it means jack shit. I remember being shown that when I was being told the KAI was the new and better turbo
Didn't happen at all. I'd have to find my dyno sheet. My current setup needs an exhaust restriction removed then a re tune but hopefully will be around 300rwkw, touch more with any luck
Yes, already written off the HKS.
Not worth it judging from you replies.
Which Hypergear did you go for?
Yes it was unfortunate and hardly honest of HKS , or their reps , to claim the KAI was going to be as good as the Pro S version .
I remember looking at pics of that turbo here and thinking hang on , no way the 0.64 AR GT28 T3 housing was going to flow like the Pro S one . The machined out turbine housing may flow a little better than it would with a GT28 turbine in it but from Garretts questionable turbine maps the efficiency numbers aren't very good .
I don't think any turbo with the cropped GT30 turbine ever worked terribly well unless it had one of HKSs GT30 turbine housings machine to suit . For some unknown reason Garrett haven't offered their GT30IW housings to suit this turbine , maybe there isn't enough material in their castings .
Just on power figures and 2835 Pro S , there was an optional 0.87AR Pro S housing if you didn't like the usual 0.68 one . Don't know the boost onset difference but power limits would have been higher with it .
A .
@89CAL: From following hypergear's thread, I remember you've got one of their testing ball bearing ss2. I have the same turbo internally gated. Obviously not as responsive as the 2835 but pulled 312rwkws on 98 fuel, 20psi by 3800RPMs. Its more of a 3076 in .82 turbo. They have made an vnt housing for it, unfortunately only for external gate. Buy that housing and it will pulling 24psi on 3500rpms and that will be about the same or better to a HKS2835 ProS while making heaps more power.
Edited by GeorgesR34
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 馃檪 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
    • Welcome!  Can't go wrong with a Stag.
    • Looks good. Nice height.
    • Hey all, a little help from the Stagea hive mind plz.. I'm days away from buying either a 2002 Stagea 250tRS AR-X Four, premium leather, power seats and all the old switches etc that go with it, or a 2002 Stagea 250tRS VR-X Four AERO, pov pack, cloth seats etc, with coil overs, sports zorst, comes with original zorst and suspension and parts. (I think I've got the models right?) Both are VQ25DET, have 160000kms, both straight no rust both with $2000+ in recent servicing receipts, both ride on aftermarket 18" rims. The Aero has a replaced turbo as well. I like the cool factor of the Aero car but the AR-X has never been modified. Neither have been driven hardly at all in the last 5 years. Any thoughts on which one or does it come down to personal preference? davemoto
