I wanted to use a neo head on my series 2 gtst. I've searched for hours on different forums but couldn't find the answers I'm lokking for.
1- will my greddy plenum and 6 boost manifolds fit onto a neo head?
2- what are the complications with doing the neo head conversion apart from the raised compression ratio?
Currently the car is running 360rwkw on stock motor and I wanted to start building an engine on the side to drop in when this one gets tired.
I don't want to start changing manifolds. I'm budget conscious but I also understand its not going to be cheap.
The head I was looking at was the lewis engines rb25 neo ultimate head package.
My application is mainly just eventually just a crazy weekend street car and monthly drag car.
I will eventually chase more power but for now I will just go to the limit of my gt3582r.
So basically I want to do it in stages as money becomes available.
Any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/441506-neo-head-help/
Ex manifold same. Inlet ports different shape. Would therefore benefit from correct inlet manifold.
Having to change manifold shouldn't be a problem. Simply buy new manifold, and sell existing one after the swap is done.
There are also various sensor differences that you will want to take into consideration, depending on what ECU you're using.
https://www.sau.com.au/forums/topic/441506-neo-head-help/#findComment-7249887
I have not seen them side by side but I seem to remember people saying that R33 and R34 RB25DET inlet manifold gaskets are the same , something to check on .
If I was building up another engine I'd leave the Neo head for that one and get pistons to suit it . Maybe even buy a complete Neo to rebuild .
A .
https://www.sau.com.au/forums/topic/441506-neo-head-help/#findComment-7250712
GTSBoy is correct.
Exhaust is the same, intake it different.
Be mindful that NEO's have a different piston shape to accommodate for the combustion chamber size. Simply installing a NEO head on a R33 RB25 will result in an unknown compression ratio, potentially making the motor more detonation prone and counteracting your efforts.
Consider the value in the swap before proceeding. The R33 head has proven a good performer all the same.
Edited by GTScotT
https://www.sau.com.au/forums/topic/441506-neo-head-help/#findComment-7251678
  • 10 months later...
Hello this is my first post/reply early model neo engines 1997-1998 versions share the same ports and cas as s2 r33 so all manifolds are interchangeable only major difference is the rear oil seal seat you will need neo flywheel r33 flywheel fouls on it very easy conversion to do no wiring changes just flywheel hope this helps
https://www.sau.com.au/forums/topic/441506-neo-head-help/#findComment-7485701
I'm running R32 flywheel on Neo also. No fouling.
That particular "early Neo" situation is a special one I think. I don't think that those engines are true Neos. These are the ones that were seen in some of the Stageas around that time, right? They look like a cross between a R33 and R34 motor, with nothing looking quite right.
https://www.sau.com.au/forums/topic/441506-neo-head-help/#findComment-7485877
Correct was unlike the s2 engine or for a fact any 25 I've worked on.i will post when the I pull engine out again this week for a kero build I'll take pics of rods pistons head oil pump and lifters just for reference purpose the block has two oil returns as well so will be good to see what you all have to say and what is meant by true neo
https://www.sau.com.au/forums/topic/441506-neo-head-help/#findComment-7485908
Good idea. I'm sure the information on them is already around here somewhere, but finding it might not be easy. Another post with the info you plan to get will be welcome.
For reference, when I was looking for a Neo for my R32 a local Jap wrecker had one of these engines. I had a look at it, decided not to touch it. The concencus from a few people I asked, one of whom is my bro-in-law who runs a performance workshop and has played with nearly every such engine, is that these "not true Neos" are just that. I think they are old 25s with a few Neo looking bits and pieces on the outside. Not the small chamber, solid lifter head.
https://www.sau.com.au/forums/topic/441506-neo-head-help/#findComment-7486003
Cheers for putting me strait about this apparent gap filling engine I never pulled it down before I put it in was just a cheap thrash engine and copped it for a year so will be very interesting to compare pics of rods heads and generally the whole engine I'll hopefully post it by early next week my health will be the only hold up cheers GTSaboy for your input
https://www.sau.com.au/forums/topic/441506-neo-head-help/#findComment-7486042
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
