If you really do not want the car and you want him to return your deposit , tell him you are going to contact NCAT (Goggle it), that will do it.
I just had him there and I am sure NO dealer wants NCAT involved. :ban:
Consumers Affair have NO REAL muscle but can get a result at times but only if the seller wants to settle to save their good name, NCAT has the power to make a decision and once they rule and the dealer does not comply they can have their license suspended.
I think most dealers talk crap, some more than others=EL
Sorry, I forgot to mention, you have to be able to prove what you say is true.
Just because a lot of people say something that does not make it true unless there is some sort of proof.
Thanks mate, EL had returned my deposit yesterday but still it takes few days for it to arrive on my account, so still need few more days to prove it.
That seems to be the plan if you look at YouTube.
Actually in the video he mentioned he wants to keep it it is so good, maybe he will have to keep it.
Edited by superben
Phil originally bought a MP3 BNR34 to be his personal car but he sold that also. He subsequently bought a BNR32 N1, and sold that too.
Quite a few cheap n nasty cars come from sleazy 'whorehouses' over yonder.
Sad to say it; but some were really lovely cars - once!
Just noticed he took all the videos about the GTR off youtube. All three of videos, gone now.
I looked at the videos just before they went off. Someone made comments about how this car had fake papers, clock wound back and that they have all the photos to prove it. An hour later and the video was gone.
haha maybe he is starting to realise he wont get away with what he is doing so easily anymore!
  • Like 1
Despot may refer to:
  • Despot (court title), a Byzantine court title
  • Despotism, a form of government in which power is concentrated in the hands of an individual or a small group
  • Despot (rapper), rapper Alec Reinstein's stage name
  • Despot voda or Ioan Iacob Heraclit (1511–1563), a prince in Moldavia
New update: got full deposit back from EL , thank you guys, this would never be able to achieve without any of you guys!
Great news mate. Well done.
Best of luck with finding your 34, be sure to post up your new ride when you get it.
All the best.
Edited by mic087
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
