A friend of mine came up with a simple smart suggestion for protecting the bottom of the front bar from scraping (besides angles on driveways).
By tracing the shape of the bottom of the front bar on to a piece of cardboard and then having the same shape cut out of sheet metal, this could then be bottled on to the bottom. The only problem I could see is too recess the front edge back a few mm so that you don't take out pedestrians legs (or possibly be defected).
Does anyone have any suggestions/ideas for improving this simple idea? Any ideas on the shape etc to improve it from being just a protection plate, to maybe something that could be a little more sturdy.
Cheers!
-Alex
i already did a similar thing. i bolted in some aluminium supports that run from the under tray to the bottom of the front bar to stop it flexing when i bottom out on my driveway.
the other idea was to stop the top from poping off. (im sure u know where i mean, between the front guards and the headlight)
worked fine for a while until i had scraped through the bolt and the support fell off...
i think the best idea would be to drill some holes in the bottom of the bar and just run a series of bolts through it. so the heads of the bolts get scraped off then you just replace them...
I did this about 4 years ago.
Its a simple bash plate. I just got a sheet of metal cut it so it covered the bottom of the bar and extended back a bit. bent it and pop rivited it on.
:D .. depends how much scraping you do and how think of a metal you used
I have to say that I like the idea of the dome headed screws.
But honestly I prefer the idea that mind flux suggested - a "bash plate"
Mindflux - any tips or suggestions?
-Alex
Personally I'm more worry about the scraping of the lip and splitting/delamination of the lip, that what's happening on the bottome of the bumper bar. If you really need to put something there...then using a couple of pieces where you get the most scrapes should be sufficient...
My only suggestion, is that seeing as most of the damage occured close to the front lip of the bar, it would be useful to buy a thick rubber strip to run along the bottom of the lip, so that the rubber can cushion the impact/scraping against the driveway.Thickness of the strip is important in reducing the amount of force transmitted to the bar. You dont want it to thick, otherwise it'll be to obvious. You can paint it the colour of your car to blend it in...hmmz..I might see where i can get some. Obviously being rubber, once a year you'll probably check to see if everything is still holding up. Pop rivet is not suggested, as you can't replace anything. Bolts would be a better idea.
Tell me if it's crap or not...
I checked my front bar today, their are 2 main points on my '95 GTS-t M-Spec front bar that get scraped however I did notice a hair line split in the paint.
Upon further inspection the very bottom of the front bar has actually been split from impact on my driveway (or somewhere else). I don't think putting something at the bottom would have prevented it, all it would have done is stopped the bar from getting scratched.
I was busy early..sorry for da kinda confusing beginning on my earlier post...
What I meant 2 say was that scraping shouldn't be your concern since it's at the bottom, not like anyone is gonna crawl under your car 2 have a look at it...wat u should b more concern about is da splitting/delamination along the bottom lip..datz harder to fix..once broken..it's never as good as new...
Benm..adding a strap where u get the most impact is useful in that it reduce the delamination effects during impact..as the metal will carry the brunt of the impact. Also being a bit more rigid that a carbon part, it will reduce the the amount of twisting/flexing of the bar. This is one of the causes of the splitting you see on your bar.However, what you need to be aware of is, that even if it might not flex at the bottom lip of the bar, it might flex somewhere else..and so u might get it cracking at another attachment location..just something 2 bear in mind..
The rubber strip solution( i'm beginning to like my idea more :)) is good in that instead of trying 2 hold the bar rigid, it instead is trying 2 absorb the impact energy...it's not trying 2 resist the impact...it's absorbing it... only thing is..being rubber..it's not very durable in term of wear and tear..so it'll need replacing...
Any solution we propose is only effective only if the add-on touches the road/driveway surface b4 the bar...otherwise..it's not worth having it there... thus, the part that we decide to add on need to be sufficiently thick...but not so thick that you can see it when standing in front of the car....
Sorry 4 da long post.
J
I was thinking of using neoprene. Like you get on kitchen chopping boards, sort of hard plastic. At marine/boat shops they have this neoprene in a slippery/frictionless compound. I was going to bolt some of this to my bar at the wear points and use them as sacrificial nodes.
Just routinely replace it. I've got a carbra and it is a mess from scrapping, so I thought I'd get it modified and sew holes in it for the nodes to stick out through.
I was going to shape the nodes sort of like a half flat donut and bolt them through the centre.
I am reluctant to use anything like dome bolts or metal sheets, cos they might rip out if scraped too hard, and wreck the bar. This neoprene is a frictionless compound and is more likely to skid along the surface every time.
Looking at the posts here maybe I should go into production....lol
the only problem with that is i imagne it would be quite thick? so it would stick out a fair bit.
making driveway clearence even harder.
i scrape every day going in and out. but if i had anything thicker than about 5mm i could not get up the driveway at all.
Ash.
Ahh the joys of living in a new housing estate where all gutters are the curved smooth type. I still scrape but only when their is someone parked out the front and I have to take a tighter line. Other than that I've worn a bare patch in the grass about 1m on the side from where I take it at a wide angle.
I have a friend who used 2 layers of black masking tape. It works in a way, cos the front bar never gets any paint rubbed off, only the masking tape. I guess it helps when u just 'scrape' a kerb or road surface, but it wouldn't help when it's a stronger impact. I would think sheet metal makes a horrendous noise when it gets scraped.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
