Need someone decent. I want to cut open the rear muffler on my E36 M3 and do a well known modification to it to get some more nice noises from it. Basically, welding, cutting, fabrication. I just want it done with quality materials and neat tidy work. I've seen some horror stories (just poor workmanship) on some of the BMW forums so be good to get a recommendation of someone who does good work. The closer to Dandenong the better.
I've put together a pdf of the process as pics are fun. Only step that is missing is packing it with SS wool.
Thanks guys.
BMW Zorst Mod.pdf
https://www.sau.com.au/forums/topic/441583-exhaust-fabricator/
Thanks guys. Spoken with Scott and he's looking into it for me. Someone from the BMW world recommended Andrew from TrackArt too, though I thought he was a cage fabricator rather than exhaust...
Anyhow, I'm sure I've got some good options now.
Yeah must admit mild does give a nice throaty sound alot easier compared to the raspiness of stainless which seems to be a little more temperamental to muffler choice...
Saw my 33 the other day and he had a nice new mild system made up for it...sounded nice...
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
