Hello guys,
I have a built RB30 with a 26 head and a PTE6266, I only have access to 98RON pump fuel.
I am currently pushing it to just under 1.6 bar with no pinging but am itching to push it even further. What do you guys think? Would a low 8's Static CR take 1.8 bar on 98 pump fuel?
Any feedback/experience would be appreciated :)
Cheers,
Sam
https://www.sau.com.au/forums/topic/441590-how-much-boost-to-run-my-6266d-rb30/
There are so many variables that the only way to know is throw it on the dyno and see
I built a 2630 with twin GT-RSs and 9.5:1 static comp on E85 and I only expected to run 24psi and so far we're up to 28, went 30 but the spark gets blown out, but going from 26 to 28 it picked up 25hp at all 4, when we sort the spark issue then we will try 30 and see what happens, if it picks up another 20-25 HP we'll try 32 and so on till it no longer makes decent gains or get to high of a knock level
Boost doesn't kill engines poor tuning and preignition does
  • 7 months later...
That is true, but you're blessed with E85. I'm stuck with pump fuel that was why I wanted to see what would be a safe limit.
what power is it making with the 6266 at 1.6bar?
Depends on the dyno really. Mine maxed out at 615whp at 1.6bar. Posted a dyno sheet on RB30 thread.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
