right i got the rwc today and they told me afterwards they have processed it and now i only got 7 days to find the parts..
THINGS I NEED:
Rear rotors but marz well do front to
Tie rod end on drivers side
Windscreen
Rear suspension
freaking out cost me $175 for cert and only last 7 days, permit cost $80 and im finding it really hard to source the right parts new, repco dont have the part codes and no1 else i have tried..
Go to Nissan...They have all part numbers.
If you are aloud to go for aftermarket check out justjap. I think they have everything that you are after except for the windscreen. Otherwise start searching the wreckers via google. Goodluck.
For the tie rod end you must specify the year, awd or 2wd. Nissan should be able to do it from your VIN no.
For the windscreen just ring any autoglass supplier with your year and model and tell them you want the factory tint and not the windscreen heater (if you don't have or want the windscreen heater).
Cause there's people on here talking about not been able to find the rotors and either grind them down to get them to fit or just replace them for skyline calipers?
anyways thank you ill try them, but everywhere else only know about m35 and not c34.
mines 1997 c34 with button 4wd
Tried nissan they dont have a clue of the part number for the rotors niether does everyone else but have found a LEGEND of a bloke thats got a mechanic shop in bayswater and are stagea owners them selves, there going to do everything for my car for me :)
Aaron "st@gea" PM me your model and chassis number. I can then get you all the genuine part numbers direct through my parts supplier in Japan.
Edited by ECR33_RB25DET
Sweet will do ill chase up my vin tomorrow, the car is at a skyline workshop in Bayswater at the moment, they own some stageas so im hoping they finish it for me in time, but i will get that from for future references so i can order parts myself, cheers buddy
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
