Parting out my S13 project car as I will no longer have time to complete it or drive it so everything must go.
S13 origin type2 50mm rear over fenders as new condition three tiny pilot holes drilled on each fender for test fitting $300
S13 Dmax Style 40mm front fenders slight chip damage from shipping $230
S13/180sx Apexi Power FC ECU + Hand controller Serial no. PFC SR2015 020-0601 $700
SR20 Kelway steam pipe manifold external gate suits T3 flanged turbos brand new only test fitted $550
S13/180sx Blacktop SR20DET has 98,XXX kms on engine minus turbo,manifold,ECU (PFC can be negotiated with price) included KTS extended baffled trap door sump, engine loom, starter motor $1600
Trust/Greddy rocker arm stoppers brand new $100
S14 Front lower control arms pair $120
S14 Front knuckles and hubs has NISMO extended wheel studs $150
5 Stud rear hubs pair $120
R32 rear handbrake shoes pair $80 dust shield slightly bent on edges.
R33 hand brake cables $50
OR
Complete 5-stud conversion
$450
S13/180sx 5sp manual gearbox with shifter will needs new shifter boot $450
Extreme clutch puk clutch used condition still 70% $150
SR20DET flywheel $50
S13/180sx Manual master cylinder $30
S13/180sx clutch pedal $30
S13/180sx Brake pedal $30
S13/180sx manual tail shaft $80
OR
Complete manual conversion for S13/180sx including clutch
Including clutch $ 750
Excluding clutch $550
S13/180sx/R32 rear traction arms pair $40 or $20 each x2
S13/180sx/R32 rear camber arm pair $40 or $20 each x2
S13/180sx/R32 rear lower control arm $60 or $30 each x2
S13 track only shell sun roof model
Non rolling included is s13 power steering rack, and cross member all windows still intact and doors, fuel tank.
Rear panels cut and welded for rear over fenders.
Only has epoxy black primer.
Has tubbed front.
$400
Only holding onto to shell for 3weeks then it will be scrapped get in before it goes to the junk yard.
Location northern suburbs
Additional pics can be sent upon request
Contact Anthony
0466111592
post-38352-0-27633000-1396879140_thumb.jpgpost-38352-0-19241700-1396879149_thumb.jpgpost-38352-0-44395600-1396879159_thumb.jpgpost-38352-0-08266200-1396879165_thumb.jpgpost-38352-0-10552100-1396879173_thumb.jpgpost-38352-0-00726100-1396879180_thumb.jpgpost-38352-0-55119100-1396879192_thumb.jpg
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
