Fs [Syd]: Nissan Skyline R33 Series 2 Gts-T With Loads Of Shit On It.. Has Gate, And Launch Control - More Awesome
I will soon :yes:
Just need a quiet place to do it, it's freaking loud and shoots flames out of the gate & exhaust LOL
Got bored and installed Splitfire Coilpacks, no more silly misfires now.
Ideally I want to sell it, but I doubt I will sell it - so I might just keep it until someone gives me the right coin for it.
By the way, never thrashed.
  • 6 months later...
Still for sale, however now car runs a set of Siemens DEKA IV 875cc 40mm Injectors with a Top Feed Rail.. not to mention motor now happily ingests 23psi :)
This is me taking it easy:
  • 4 weeks later...
will swap for a car that has/is:
  • less than 10 years old
  • 4 doors
  • has ABS
  • has more than 2 airbags
  • has sunroof
  • has climate control
  • decent condition
  • loads of creature comforts
No Commodores or Falcons (I don't mind the latest shape Commodore but in reality noone will swap that for a R33 lol)
  • 4 doors
  • has ABS
  • has sunroof
  • decent condition
Interesting...... ;)
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
