So my mates Skyline got broken into last night (Calwell) and they're about so i would suggest to double tripple check ur pride and joy.
any info of people doing this would also would be much appreciated
be good and stay safe Gus
https://www.sau.com.au/forums/topic/441632-thieves-about-lock-chain-ur-sht-up/
4 vehicles in Kambah last week. Definitely car theft is on the rise again locally.
Several in Canberra the week before from all over mainly North side and Woden area.
All types Makes/Models not just ours.
I know it happens all the time, but the increase just lately is a real worry.
Immobiliser and Club Lock... CHECK! always.
Still, even if the car is not stolen, the pain of fixing the damage is in the Arse.
Had this happen years ago in Lyneham, my old '85 Bluebird was never the same and all they got was a mini maglite. :/
  On 08/04/2014 at 10:47 AM, B-rice said:
Usually pull out a fuse. And leave nothing tempting inside as I live in the ghetto. Part of the south.
Yes - yes you do
4 from your suburb over a few nights
  On 08/04/2014 at 9:52 AM, GTRKat said:
Mine is in the garage and gets parked in. Also don't let very many people know where I live.
Overparanoid but I'd kill someone if something happened to my GTR.
For sure, garage and padlocks.
Problem is when its gone theres no one to kill. Its too late.
Like finding your car with the window smashed for stealing the stuff inside. The bastard has long gone and your left standing there feeling angry and powerless to do anything about it.
So never leave it for long if you take it out. Its only about 5-10 seconds for someone to smash the window and steal your phone.
Lock up people, and avoid the sadness.
Ps: what is a key safe? is it a place thieves know to look for important keys? Put your safe into thick concrete with reo.
When i was 12 in Melbourne our house got broken into, they used power tools to get into the garage and steal dads stuff. You gotta make it hard for the bastards, I lock up tools and cut power to the shed.
If they know what they're doing and if the car has a alarm they will pop the bonnet pull fuses to turn it off, Happend at my old car yard they took the whole interior from a calais was 8g or something stupid to replace the genuine seats.
We would aslo came in to find cars sitting on the ground with no wheels maybe if they were nice they may have put a millk crate under so they could get there jack out lol. but jacking cars up in random spots just to get it of the ground ruined other parts of the car skirts ETC
Anyway lets face the drugs today are bad and these kids will be wired as ten men at 2am while we're sleep or whatever ;) they want a fix and will do anything at the time to get some coin.
have a good day sau.
A key safe is a normal safe with key hooks. Stops the walk in steal the keys and drive away that occurred about a year ago in Sydney a few times. It stops 99% of thieves in their tracks, if they want keys.
The 1 ton safe that attracts them, but that just has the boring stuff in.
But hey who would bother trying to crack/burn/blow up a safe for a $20-30K car. There's plenty in carports or out in the open. And bypassing the alarm etc is probably easier if the keys are locked away.
  • 4 weeks later...
Insure for a high agreed value. Lock in a garage. And don't worry about it. Going to all these extra lengths won't stop a pro. Get a house alarm installed throughout and in the garage. They won't make it in the front door without an alarm going off, let alone have the time to steal a car.
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 馃ゴ
