So I have just bought another r33 liner series 2 and I'd soon like to upgrade the factory plenum to a front facing greddy style. I'm a cnc machinist and have the skills and access to machines to make most adaptors that I think I'd need to change the plenum whith out having to do any aftermarket upgrades such as afm and computer. Just for the moment id like to keep the stock computer running. So my questions are what things will I find that need to be changed or replaced when changing my plenum. Eg throttle body, injectors / rail, bov etc.
For the moment the main purpose is so I can setup a fmic without having the stupid crossover piping that is mostly required when doing a fmic. I don't want to use one of those fmic that have both pipes on the passenger side like factory.
https://www.sau.com.au/forums/topic/441669-rb25det-front-face-plenum/
I like mine because it tidies up the bay so much. Not sure about with a stock computer. It would possibly be either unsafe or too rich and run like a pig anyway. Theres also the question of leaning out the back 2 cylinders. Im not saying it does or doesnt happen but ive got my link g4 adding a bit more fuel to cyls 5 and 6
There is a huge thread about installing one and what you will need. Think it is in the forced induction section anyway
I ran a greddy copy with a standard ecu no problems at all... Even had it on the dyno to do a power run before any major power modifications were started and all stats were sweet as far as I could tell. I'm no tuner tho by any means so don't take my words as the be all and end all haha I'm just saying I had no problems running one with standard ecu. My car had a 3 inch exhaust and front mount as well at the time...
Proven to make siet all gains with low to mild powered RB motors..
That RB20 Propaganda fella Roy proved it on the dyno.. save money, buy awesome turbo, buy awesome injectors, buy awesome ECU and rip skids
Fair call if you think it's pointless but I'm keen to tidy up the engine bay also. If an adapter was used for the factory throttle body, what else is needed? Do the injectors fit? What about the fuel rail? I saw something about std injectors needed a bigger o-ring to fit in the plenum properly. I want to know what I'm in for if and when I buy the stuff. If anyone can show a link to these threads as I'd like to read up on them a bit
Thanks guys
Edited by linerlover
Injectors and rail fit fine, minor mods need to be made to the rail piping in some cases
I told you, there is a thread on here somewhere that shows you everything you need to do. Very in depth, and very detailed
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
