Hi there,
in the ongoing discussion on the miracles of sea travel as a cure for aging (a slow cruise from Japan to Australia seems to take years worth of driving off), it struck me that there was a big difference between the km's showing on GTT vs GTR cars of the same era. So i did a bit of late night research and captured a sample set of ~ 230 R34 vehicles.
Average km's driven by GTT's 1998 to 2002 = 7797km/yr
Average km's driven by GTR's 1999 to 2001 = 4672/yr
This doesn't seem like a great difference yet for some years there is an average of half the km's advertised for GTR's compared to GTT's. There's also a strange effect that later model vehicles are offered showing higher average km's than earlier models.
Published for comments and discussion.
GTR Count km/yr GTT Count km/yr
1998 0 114675 84 7167
1999 58159 13 4274 120755 54 8050
2000 100000 1 7143 111338 54 7953
2001 65140 8 5011 118364 17 9418
Average 66115 22 4672 116978 127 7797
No i'm not a dealer but wanted to understand where my car sat.
Cheers
Ned
Edited by ned
90% are altered. Your research is futile unless you have the true km.
But if they were true, I would say it is due to a gtr being majority a weekend car and a gtt to be a every day car.
The one does cost 4 times as much as the other after all
They also probably don't bother with winding back GTST's where as GTR's are a lot more desirable with low kms.
I don't think I've ever seen a GTR at the dealers with over 100,000kms
I did note that dealers GTR's were all around 50-60,000 km but GTT's at dealers could be 90-120,000 km
where are you getting the data from? carsales in australia?
your better off basing the data from japan so you get a better idea of actual kms
http://www.japaneseusedcars.com/auction/auctions_results.htm
search through these and you will see there is plenty of GTRs with close and alot more than 100k kms..
It's all to do with winding back surely. Nothing to do with the cars themselves and how they've been driven. Just it might seem a bit more plausible that a GTR has been a weekend car, so they'll wind 'em back to 80,000 odd and hope to get a pretty penny from some poor sod. It's not as believable that someone has kept their GTT in the shed as a weekend car - especially when quite a few are autos on Carsales too.
(I'd keep an Auto GTT in my garage for weekends tho... Still a very fun car)
The R32 GTR has done 3,330kms per year on average for the last 3 years (weekender)
Prior to that it was mostly off the road since 2006. (2 engine rebuilds and many modifications including a respray)
I bought it with appx. 100,000 on it late 2003.
So it has done on average
10,000kms per year for 10yrs in Japan (providing clock not rewound)
1,000kms per year for 11yrs in Australia (10,005 in the last 3)
KM's on clock as said above does not indicate how the GTR has been treated.
(my daily IS an auto 34GTT high flowed :) ) 140,000kms on odo
Edited by Sinista32
KM's of R3' series Skyline is pretty much all Bullshit in Aus.....
I imported my 34GTR with 107,000KM's on the clock and it's in better condition than those of half that :-)
If you look on Carsales even R35's these days have between 20-50,000 KM's on them from 2009. The chances of getting an R34 with a genuine 50thou is unlikely, and you'd be paying a pretty penny for it.
But on topic, GTR seems to be locked away in garages and only brought out on weekends. GTT is seen more as a daily drive
Yes all data was from Australian sites (Carsales / Drive / Gumtree) as when I mention the km's on mine (100,000 km plus for a 1999) I often get strange comments about how high it is ....."because I saw one with XXXX km for sale recently"...
I just thought I'd put some actual data behind a suspicion I had that GTR's get more "polish" before arriving than GTT's.
But maybe all the comments are wrong and they ALL only get driven on the weekends?
Edited by ned
Hey GTR-34A thanks for the link, i just had a good look at this site and its a good read! Do you know why so many R34 GTR's on there would be sold with no mileage readings?
no problem,
yea i did notice that, not sure why... maybe its just a hole in their records...
pretty handy to see what cars are selling for though... and to compare what actual genuine 50k kms car sell for in japan, and see what the dealer advertises them for over here... easy to tell things dont quite line up
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
