Works been extremely slow for me down and i'm running out of stuff to make and do to keep myself occupied as i just finished up a massive build for a mate of mine. If anyone wants little things like Catch cans, Overflow bottles, Washer bottles, Power steering reservoirs and custom surge tanks made up, Radiator header tanks. Rb26 RWD and 4wd extended sumps(can do sumps on exchange basis if urgent as i do have a spare standard rb26 sumps)
To save the question being asked about bringing the car to me, I'm located in cairns so just send me a message and i'll see what i can do to help out. I have access to a 32 and 33 and s13 and possibly a r34 gtt & S15 for mounting points and what not.
Obviously due to every car being different i can't do exhausts or intercooler piping as everyone has different ways and positions of mounting there coolers and that screws shit up bigtime.
I do however have spare heads/blocks for dummie up and making or modifying turbo manifolds and can quite easily do a Balance pipe mod for rb26 low mount manifolds if you're having that nasty turbo shuffle problem.
And no i am not a business and don't intend on turning this into one. I'm not expecting this to get a huge response. Just simply a few small cash jobs to help cure my boredom while work is quiet.
split pulse t04z rb26 manifold - Cant find completed pics.
power steer reservoir were charcoal cainster use to be.
undercar r32 gtr surge tank.
Catch can/radiator breather setup
post-78330-0-64714100-1397071907_thumb.jpg post-78330-0-63372000-1397071949_thumb.jpg
Sump extension and Balance piping a set of tomei expreme manifolds(will add finished picture this arvo)
post-78330-0-04289300-1397071990_thumb.jpg post-78330-0-43984400-1397072060_thumb.jpg
https://www.sau.com.au/forums/topic/441713-little-bits-and-pieces/
  • 1 month later...
How much for a nice oil catch/washer bottle combo for a r32 gtr rb26dett?
Only just saw this as i've moved interstate, will work it out and send you a message. sorry for the delay i'm now located in Darwin.
Interested in a catch can to sit in front of the battery of my 32 gtr.
Question, are yours baffled?
Also interested in awd sump. 8-9l baffled
Yes i baffle the catch cans, and Can no longer do the sumps on exchange basis as i dont have any spares. will pm you aswell.
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
