I understand the ratios in the GTS4 are shorter and suitable for putting in a GTR. However my question is what is the best way do do this. Scrounge around for a wrecked 4 (Of which I cant imagine there are many), buy new crown wheel and pinion or is there an aftermarket option or different donor vehicle?
The rear GTR diff I have has a Nismo LSD in it so obviously I want that to transfer accross.
Ah ok. Was a bit doubtful about the wisdom of finding a 20 year old diff and then trying to track it. Guessing it is drug money for a new version from Nissan?
By the way did it give you a good gain? I am sick of getting hosed by Emos out of tight hairpins etc on hillclimbs and the like.
Yeah I didn't look into the new price from Nissan; after all you are only reusing 2 gear wheels not the centres.
As for the gains; I did the change years ago so I can't really confirm back to back any more...I do know that I can hose those pesky Emos and WRXs off the line these days (it launches like a champ). More importantly in my case, because I have to run nasty 80's bush bearing turbos, lower gearing definitely helps get them come on earlier. The only place where I came close to having an issue was Phillip Island, and even there I was only doing about 6000 in 5th on the straight.
GTR gearing is pretty tall. So you tend to find that on tight hillclimbs and supersprint courses, even certain corners on certain circuits) there are times where you are stuck between gears (eg 2nd too tall and first is too much fapping about) or the thing is off boost (say exiting a 3rd gear chicane). Shortening it up can help mean it gets on boost quicker or it is less compromised when you have to pluck a taller gear anyway. If I could be stuffed I would do a engine torque cascade graph where you multiply the torque by the gear & diff ratio and plot it againt road speed. It tells you how much powahs the car delivers.
yep, essentially. 10% shorter gears are effectively 10% more torque at any given speed, with a trade off against top speed (which has never been an issue for me on any track I've been to).
particularly useful for me because I have to run nasty, laggy r32 n1 turbos.
Hey mate I'll try and get back to you tonight; and re cages the guy I would have recommended is no longer in business....they were good and cheap but too late now.
Any decent welder can do a decent cage like my car has, if you want something a bit special they generally get very expensive. Probably easiest way is to get a pre bent hoop from Bond cages and get someone to do the rest custom
    • Where is the electrical conduit? 🤣🤣
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
