Prison Warden: "The 3 injections won't take long and you'll feel no pain. Now that you've had your last meal, do you S!n have one final wish eg goodbye kiss or a bar of chocolate or a massage?"
S!n: "Umm can I say one cheerio to my friends on SAU?"
Warden: "Nup, sorry. There's too many of 'em and you don't have a month!"
Does that mean we also celebrate your departure at the 25th Anniversary?
Must be pretty close to that date
What a way to go out Sir. Put that on the achievements list of your resume :)
  On 17/06/2014 at 10:43 AM, Sinista32 said:
JAYCE :cheers: am I pleased to hear that mate.
Lets catch-up and chat
I tried hard not to log back in but .....
There will be more of me, yes! So, g'day again!!
  On 17/06/2014 at 12:15 PM, Not a Pulsar said:
Sounds wicked. :woot:
I like him just cooz he started the "One Word Association Thread" more than 7 years ago!
Legendary Status.
That one was a but of a suprise! It's the little things!!
Thank you squire!
Yes I've given notice that I'm no longer an Exec, the day after the 25th Anniversary.
I sleep in.
So loss of the Power but not the Passion then.
Enjoy the sleep
you should know that "One Word" made it's way to QLD earlier this year and is going strong
Enjoy the sleep
It's because some of ACT made it's way to QLD :P
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
