couple of questions...i'm sitting here going through some logging i did the other night in my car...here is the scenario and i'm wondering what is the best option...being first time road tuning.
on wot i'm running 11.4 afr's in p15 n17 with a knock reading of 18.
my question i'm pondering is ....should i pull fuel or add a degree of timing? timing in this cell is 18degrees @6100rpm
my mods are in my signature
any advice would be great
thanks.
https://www.sau.com.au/forums/topic/441761-map-tweaking-questions/
no problem just trying to get maximum efficiency. can you not get detonation with too much fuel? conversly with too much ignition? seeing as this is at the high end of the rpm scale i tought perhap a degree more timing might help.....this is where my thinking was going on both.....might have to do what gtsboy suggests :)
Im a bit confused as to why your timing is going up in the bottom right cells. It climbs from left to right be a degree every few cells. It should be the opposite.
as rpm increases the time between spark is reduced...which is why i advance the ignition as the rpm climbs.
Isn't that what IGN Dwell vs RPM is for
I dunno, now that I can look at my old map it seems I had more timing up top anyway. It starts dropping but did start higher. I havent done any tuning for quite a while now
IGN dwell versus RPM is for charge time, to make sure the coil is charged before the spark event happens. As a real rough rule the timing will typically be at it's lowest at low rpm and equal/highest at the highest rpm - the flame has to chase the piston, funnily enough at 7500rpm the piston will pull away from the start of the flame 3x faster than at 2500rpm.... if you used the same ignition advance the flame would be left for dead and just generate heat for no useful reason.
I wouldn't trust the pfc knock reading.
Only true way to get the maximum efficiency for that cell.
Is to load it up on a dyno and hold it at the poad point and play around with timing and fuelling
i agree, its not accurate but its all i've got at the moment. i'm saving for a knocklink.
whats the optimal AFR up the end of the map? is 12-12.5 still optimal?
how much boost are you running? and I suggest you run less and less timing as load increases (incase your actuator hose comes off OR you get a massive boost spike).
12-12.5 is consider ok up top, however most prefer to keep it under 12.
I usually like peak torque (roughly after max boost) around 11.5 then it tapers up to 11.8 all the way to redline.
"Optimal" is whatever the engine is happy with. It takes a dyno and knock ears to decide what that is. Some engines might like a little more fuel to keep knock under control, some might like a little less timing. It really so very much comes down to the specific combo of engine (age, condition, components, settings), turbo (compressor efficiency range it's operating in, back pressure on the turbine side) fuel and a bajillion other things that you can't tell if it's really happy unless you can watch its reactions to different settings.
For example, with a certain "tune" at a given load point the engine might be pinging a little bit. The dyno operator can choose to either richen up a tad or reduce timing. But which one he chooses will depend on whether the torque suffers more on one change than the other, or if the exhaust temp starts to become a bit wild and so on.
base timing is set to 15 degrees. thats a lot less timing than is used to have...stock they are up around 20 at wot.
i hear what you are saying gtsboy.....the knock ears will be a great help..... i think all cars need a happy meter.
stock is 22, however nissan never factored in 1.3bar into the motor.. the powerFC map is just to get the car going remember that
Did you set up the base timing while looking at what the power FC was doing? I can see the first 4 cells are 15 but mine used to get close to or overlap cells further then that. I used to do base timing with a second person. One person looking at the hand controller timing and the other setting it with a timing gun. I think unplugging the TPS cancels the idle map timing so it wont jump around as much
You've probably done it fine but just asking
best to pop it on a dyno, with those timing figures on a slow ramp you will find it will knock quite abit around 3600~4000rpm (assuming that's your peak torque).
I like to ramp the cars I put on dynos around 9km/k per second.. i.e. the car increase 9km/h each second... the shorter the ramp, the less stress and usually shoots up higher numbers.
I prefer to really load up the motor and let manifold glow.. think about a track, especially the straight at wakefield it's not a 400 metre straight it's quite long, thus more load on the motor
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
