to be honest its been a very long time since i checked it....i will check it that way....i was having trouble with my idle the other day and noticed that the map shows 20 but the actual logged timing was 15 degrees so i just set those first cells to 15 anyway. previously i had just set them to 20. i will definately check it before going on the dyno.
no problem just trying to get maximum efficiency. can you not get detonation with too much fuel? conversly with too much ignition? seeing as this is at the high end of the rpm scale i tought perhap a degree more timing might help.....this is where my thinking was going on both.....might have to do what gtsboy suggests :)
You can get det even though you throw alot of fuel in there, as with ign timing. Best bet is to get it on the dyno, set up your fuel and then play with timing, Add a couple of degrees at a time and see how it responds power wise and look at knk levels of course. When you reach the point where it makes no more power or very little for the changes made, back it off a few degrees for safety and yo should be good to go......Only way to know, as you wont feel these changes on the road.
  • Like 1
thanks for all your advice guys i appreciate it. i just wish dyno's werent so costly to rent.... i'm doing my best to learn to tune on my own car. i'm tuning my wifes GTR next...however thats quite another kettle of fish the factory ECU she has was tuned by Torque performance, i'm going to tune up her powerfc the best i can and then dyno compare both ecu's....its my new hobby and i'm really enjoying it.
and here we go, just note I'm running 1.2 bar of boost, so it interpolates between 216/233kpa i.e. between 1.16 bar & 1.33 bar.. my theoretic max torque would be between 4000 4500 rpm, but saying that I haven't added much more timing after max torque as the car hasn't seen a dyno yet - waiting for the larger injectors (if I don't sell my car by then lol)
These timing values are some what conservative as I roughly punched them in a few days before a track event at wakefield
  • Like 1
what turbo and injectors are you running.... couple of degree up top difference between mine and yours.
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
