Hey guys I have wrecked an 1999 r34 gtr vspec was heavily damaged in an accident
All items are located on the sunshine coast in queensland
Most interior is available no front seats or dash though.
Carpet $100 has a 5mm hole under the drivers floor mat
Nismo 320kph dash cluster black $500 they are $695 new on nengun
Mfd with loom and facia (surround) $1000
Full set of nissan floor mats (front and rear) $100
Door cards passenger side great condition $100
Drivers side slight damage $50
Rear seat in fantastic condition $200
Other bits and peices just ask
Complete vspec rear cradle (cradle is damaged and passenger side arms are damaged) shafts and diff are fine also hubs are fine $300
Complete set of rspec brakes 8 pot fron 6pot rears 400mm rotors(front) unsure of rear size will confirm $2500 firm I know these are 3500 new and are in great condition will be freshly machined before sale pads have plenty of meat!
Sard 1000cc suit rb26 11mm injectors $500
Sard 800cc injectors suit rb26 11mm $400
Greddy profec b spec 2 black mint condition with complete loom and sensor $300
I do have some other things I havent thought of and ill get some pictures up tonight or tomorrow
Please text me on 0434 256 986 as im not always able to answer the phone
Thanks ryan
https://www.sau.com.au/forums/topic/441773-bnr34-and-rb26-stuff/
OEM sideskirts undamaged by any chance? and pics of cluster? what condition is it in, any scratches?
Skirts were damaged so went to the tip
Send me a text and ill send pics of the ddash cluster 0434 256 986 or pics will be up later tonight the cluster is in great condition no cracks or damage !
Hey guys measured up the rotors they measure 380mm front and 355mm rear
Also I noticed the polarizing on the mfd has perished around the edges so will drop the price to 800 also its the tv option mfd
most interior pieces
passenger door
front bar
spoiler and boot can be seperated
sard 1000cc injectors part number #195500 3650 made by denso can flow to 1180cc
Sard 800 cc
rear rotor thickness
rear rotor diameter
rears
fronts
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
