Hey guys I have wrecked an 1999 r34 gtr vspec was heavily damaged in an accident
All items are located on the sunshine coast in queensland
Most interior is available no front seats or dash though.
Carpet $100 has a 5mm hole under the drivers floor mat
Nismo 320kph dash cluster black $500 they are $695 new on nengun
Mfd with loom and facia (surround) $1000
Full set of nissan floor mats (front and rear) $100
Door cards passenger side great condition $100
Drivers side slight damage $50
Rear seat in fantastic condition $200
Other bits and peices just ask
Complete vspec rear cradle (cradle is damaged and passenger side arms are damaged) shafts and diff are fine also hubs are fine $300
Complete set of rspec brakes 8 pot fron 6pot rears 400mm rotors(front) unsure of rear size will confirm $2500 firm I know these are 3500 new and are in great condition will be freshly machined before sale pads have plenty of meat!
Sard 1000cc suit rb26 11mm injectors $500
Sard 800cc injectors suit rb26 11mm $400
Greddy profec b spec 2 black mint condition with complete loom and sensor $300
I do have some other things I havent thought of and ill get some pictures up tonight or tomorrow
Please text me on 0434 256 986 as im not always able to answer the phone
Thanks ryan
https://www.sau.com.au/forums/topic/441773-bnr34-and-rb26-stuff/
OEM sideskirts undamaged by any chance? and pics of cluster? what condition is it in, any scratches?
Skirts were damaged so went to the tip
Send me a text and ill send pics of the ddash cluster 0434 256 986 or pics will be up later tonight the cluster is in great condition no cracks or damage !
Hey guys measured up the rotors they measure 380mm front and 355mm rear
Also I noticed the polarizing on the mfd has perished around the edges so will drop the price to 800 also its the tv option mfd
most interior pieces
passenger door
front bar
spoiler and boot can be seperated
sard 1000cc injectors part number #195500 3650 made by denso can flow to 1180cc
Sard 800 cc
rear rotor thickness
rear rotor diameter
rears
fronts
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
