Hey guys I have wrecked an 1999 r34 gtr vspec was heavily damaged in an accident
All items are located on the sunshine coast in queensland
Most interior is available no front seats or dash though.
Carpet $100 has a 5mm hole under the drivers floor mat
Nismo 320kph dash cluster black $500 they are $695 new on nengun
Mfd with loom and facia (surround) $1000
Full set of nissan floor mats (front and rear) $100
Door cards passenger side great condition $100
Drivers side slight damage $50
Rear seat in fantastic condition $200
Other bits and peices just ask
Complete vspec rear cradle (cradle is damaged and passenger side arms are damaged) shafts and diff are fine also hubs are fine $300
Complete set of rspec brakes 8 pot fron 6pot rears 400mm rotors(front) unsure of rear size will confirm $2500 firm I know these are 3500 new and are in great condition will be freshly machined before sale pads have plenty of meat!
Sard 1000cc suit rb26 11mm injectors $500
Sard 800cc injectors suit rb26 11mm $400
Greddy profec b spec 2 black mint condition with complete loom and sensor $300
I do have some other things I havent thought of and ill get some pictures up tonight or tomorrow
Please text me on 0434 256 986 as im not always able to answer the phone
Thanks ryan
https://www.sau.com.au/forums/topic/441773-bnr34-and-rb26-stuff/
OEM sideskirts undamaged by any chance? and pics of cluster? what condition is it in, any scratches?
Skirts were damaged so went to the tip
Send me a text and ill send pics of the ddash cluster 0434 256 986 or pics will be up later tonight the cluster is in great condition no cracks or damage !
Hey guys measured up the rotors they measure 380mm front and 355mm rear
Also I noticed the polarizing on the mfd has perished around the edges so will drop the price to 800 also its the tv option mfd
most interior pieces
passenger door
front bar
spoiler and boot can be seperated
sard 1000cc injectors part number #195500 3650 made by denso can flow to 1180cc
Sard 800 cc
rear rotor thickness
rear rotor diameter
rears
fronts
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
