Hi guys I am a fairly new owner of a r33 gtst. I think I may have a problem and I am sure someone on here can help me out .
The Problem
At high rpms when I let off the throttle I hear a shhhh sound. it doesnt happen when I accelerate slowly or drive without pushing the car hard.
I have done a bit of reading and it seems to be a compressor surge. can someone help me figure this out
https://www.sau.com.au/forums/topic/441877-compressor-surge/
  On 14/04/2014 at 2:52 AM, superben said:
So technically when asking what noise or why does my car idle like shit and stall you should say it's all stock except for the bov ;)
i assumed the skyline came with a bov stock...like I said i m new to this
Yes, all turbo Skylines (R32 -R34 series) come with a 'recirculation' valve from factory. ALL of them make a 'pshhhhh' noise when the throttle is backed off. It will be louder if there is a pod filter, or if the standard airbox is modified.
Is it a psshhhhhh noise or Zututututututu noise :whistling:
They do come with a bov stock, but for some reason people change them.
Take a photo of your engine bay.
I guessed auto cos you don't tend to hear the bov with an auto as you don't lift off the throttle on gear shifts.
Look into getting a shift kit to liven up the auto,and to make it live longer.
Model specific dual port. Should be O.K, I think you can make it so it only runs plumback (which is what you want)
If you have the stock air box and can hear it, chances are it might be venting to atmosphere, Spring rate might be a touch to high as well
Set it to full plumback (I'm sure you can have one, the other, or both on these) and see how it goes
That valve will do what you need if it is hooked up to recirculate properly. Should be some kind of adjustment on there.
unfortunately that will score you a defect notice though if the police know what they're looking at. If you want to replace it the stock GTST valve or GTR valves are good enough
Hahaha.
That's pretty funny, you heard a blow off valve sound, mentioned it had a blow off valve and then sure enough it was the blow off valve making the sound!
Welcome to the forum, read heaps! There is an endless supply of info to help you.
Put a stock bov on, a defect isn't worth it.
thanks for the input guys I will adjust the bov and see what happens. I personally don't like my car making any kinda noise that attracts unwanted attention from cops or anyone. Unfortunately the car came with the aftermarket bov. the only mods I have done is a Tanabe exhaust and hicas elimination bar and deep dish 18 inch wheels.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
