Hi guys I am a fairly new owner of a r33 gtst. I think I may have a problem and I am sure someone on here can help me out .
The Problem
At high rpms when I let off the throttle I hear a shhhh sound. it doesnt happen when I accelerate slowly or drive without pushing the car hard.
I have done a bit of reading and it seems to be a compressor surge. can someone help me figure this out
https://www.sau.com.au/forums/topic/441877-compressor-surge/
Yes, all turbo Skylines (R32 -R34 series) come with a 'recirculation' valve from factory. ALL of them make a 'pshhhhh' noise when the throttle is backed off. It will be louder if there is a pod filter, or if the standard airbox is modified.
Is it a psshhhhhh noise or Zututututututu noise :whistling:
They do come with a bov stock, but for some reason people change them.
Take a photo of your engine bay.
I guessed auto cos you don't tend to hear the bov with an auto as you don't lift off the throttle on gear shifts.
Look into getting a shift kit to liven up the auto,and to make it live longer.
Model specific dual port. Should be O.K, I think you can make it so it only runs plumback (which is what you want)
If you have the stock air box and can hear it, chances are it might be venting to atmosphere, Spring rate might be a touch to high as well
Set it to full plumback (I'm sure you can have one, the other, or both on these) and see how it goes
That valve will do what you need if it is hooked up to recirculate properly. Should be some kind of adjustment on there.
unfortunately that will score you a defect notice though if the police know what they're looking at. If you want to replace it the stock GTST valve or GTR valves are good enough
Hahaha.
That's pretty funny, you heard a blow off valve sound, mentioned it had a blow off valve and then sure enough it was the blow off valve making the sound!
Welcome to the forum, read heaps! There is an endless supply of info to help you.
Put a stock bov on, a defect isn't worth it.
thanks for the input guys I will adjust the bov and see what happens. I personally don't like my car making any kinda noise that attracts unwanted attention from cops or anyone. Unfortunately the car came with the aftermarket bov. the only mods I have done is a Tanabe exhaust and hicas elimination bar and deep dish 18 inch wheels.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
