Hi
One mod I have wanted for a long time is to lower the seating position in my R34 GTR.
From what I have found so far the Bride Stradia/Gias seems to go as low as possible using off the shelf parts.
Does anyone in Brisbane or GC have an R34 GTR fitted with these seats that I could sit in before shelling out the cash?
Am also interested in what the rear access is like with them, as they do not seem to flip forward very far.
Preferably genuine items, but if the replicas as exactly as low then that will also do.
Thanks in advance
Stretch.
https://www.sau.com.au/forums/topic/441893-bride-stradia-or-gias-r34-gtr-demo/
I did sit in Chris's car but that is a Zeta fixed back seat and I would really like too check out a recliner style, mainly to see how far forward it fold and how low it is.
If Bride's are not ADR/legal then are all the people that have them just taking a risk being defected?
if the cheapass saas, monza, autotechnica etc seats can be adr approved it would be hard to see why the decent bride seats couldn't be. Would need to be quick-tilt type for 2doors though, soemthing about ease of exit in emergency...that's about all i know on it though
Nope, no brides.
Removed a (genuine) bride from new zed for recaros. While getting recaros mod plated, I showed the one that came out. He saw it was a bride and said no way, big no-no on all bride seats. Can not be mod plated.
  • 3 months later...
  • 1 year later...
Is a 34 gtr not low enough?
I had a low one, then raised it because I couldnt see over the dash (172cm) and then I was boosting around being all lebo. what I experienced was,
Seat belt doesnt sit in the right spot and kind of rubs around the neck instead of collar bone
very annoying to clip unclip seat belt with the bolsters
side of seat is very very close to the door
it does not recline nearly as far as oem
seat also does not slide as far forward as oem
All in all, Id rather have a 34 GTR seat than a bride stradia/gias.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
