Hey everyone, I'm after an external wastegate!!
I'm looking into Precision Turbo Wastegate 46mm Black PW46? Anyone have used it on an rb at all? How good are they?
My car is a 32 with an rb20 n boost will be around 15-20psi!!
Any feedback would be appreciated!
Regards
Ali
https://www.sau.com.au/forums/topic/441909-precision-turbo-wastegate-46mm-pw46/
They look the goods, can't say I have ever seen them before.
I use only Turbosmart currently, especially now they released the HP caps and springs. These precision ones seem to be copied off the turbosmart design anyway, so should be fine.
I'm looking into hypergear turbo! I'm in the middle of discussion with stao!!
Most likely would be this turbo with external wastegate setup: http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-481
Ok, I have externally gated a few of those housings. Just understand they are internal gate housings only, and you will need to weld a bung into the internal gate hole to block it.
Any decent gate will work fine, around that 45mm size, but don't just weld it on at a 90 degree, you need to help the exhaust flow out the gate any way you can. I use a steampipe bend and diegrind a nice merge from the flange like this. It helps force the exhaust into the gate.
Simply welding it on at a 90 causes the gate to almost flow backwards, like a spray gun. You won't have good boost control.
I was going to buy one of these gates from the US last year but was advised not to. They are only a little bit cheaper than a TiAL but apparently a lot lower quality.
Hope that helps.
go onto the DSM forum, these gates tend to jam up after several hundred heat cycles.. just pay a touch more and get a tried and tested turbosmart one... they're not much more and work as expected.
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
