I had my car running good today, went for a drive and my car just started reving high on idle so I drove home, and stared it at home now I an idle hunt goes from 1000 to 3-4000 what are the main cause of idle hunt?
You must have a vacuum leak and a big one for it to rev that high..
You mentioned you were going to pressure test, did you?
You should now.
Did you set the timing correctly? Not that it would fix your high idle issue. But it would nice for the people that have helped you to know if it worked or not.
Edited by superben
I did pressure test it the other day and found leaking injector insulators but fixed that, I'll do I pressure test tomorrow and report back. I got it close but when I took it for a drive it boosted up high but felt like it wasn't doing anything so we advanced the timing a little and it went a lot better and it also helped with a oil pressure problem I had
It's just a thermo switch for the front fan. Kicks in about 90 degrees
what fan are you talking about? the condenser fan? that's for the air con condenser to keep it at 40degree celcius. the sensor in the radiator I thought was a coolant sensor.
The sensor/switch mounted in the bottom RHS of the radiator is for the thermo fan.
If you're bored, unplug it and bridge it with a paper clip :)
my a/c thermo fan is gone....i'm putting one back in eventually.
If you're going to that much trouble, better off installing a better fan :)
The stock one is a little on the shit side
i had a good look around a few years ago but couldn't find a 3 wire fan that size off the shelf.....i didn't look too hard though....any ideas?
eh?
it's a 2-wire 12V DC fan bro lol
Just get a SPAL item off eBay and whack it on the front, and if you're keen use a different thermoswitch so the thermo kicks in earlier
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. ๐Ÿ˜ญ
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.ย  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.ย  If you hold the wand any more than 45 cms away from pretty muchย anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.ย  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.ย  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
ร—
ร—
