Hi guys just a quick what is the most power you can get from a 2.5 neo engine from the skyline 25gt without going turbo or supercharged and what would kind of price Range are you looking at?
Is it possible to get around 300hp ?
If you don't mind spending about 20k on building an engine and then rebuilding it at every oil change then you might get 300hp. But it will drive like crap, use heaps of fuel and be exceptionally unreliable.
  • Like 1
Should just by a magna ey Marc ;)
But yer not a hope of going 300hp (even at the flywheel), would need massive compression, huge cams, itbs.... Although, I shot of giggle gas would liven that boiled egg of an engine up :)
300hp is equal to 220kw, something which not even a stock r34 gt-turbo makes.
Anyways that being said, If you are keen on dishing out 5k+ some guy posted on youtube of his n/a r33. Got 140rwkw out of a N/a, which equates to around 200hp at the wheels.
Initially it was making 92rwkw, so considering its 140kw at the fly from facotry it should be: 140-96= 44kw. 140+44 = 184kw at the fly which is 250hp once modded. So if you spend 5k you can get 250hp, not impossible :P
He lists his mods in the description:
Up until the ferarri 458 came out, the F20C in the Honda s2000 was the most powerful naturally aspirated engine per litre in a car and that made approximately 124hp at the flywheel per litre. 248hp with 2.0L . The F20C is a supremely different engine to the Rb25de. the Rb25de was not made for power, that's what the Rb25det was for.
Is it possible to make 300hp from a smaller capacity N/A engine? Yes. Is it possible to make 300hp from an rb25de? Possibly. Can do you it for less then you'd make 500kw from an rb25det? No.
It's definitely not worth you time or money.
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
