Hey guys,
Out of curiosity how much power did you put out before your gearbox has blown with the rb30.
Give us a rough breakdown on the
- clutch ( single / twin / triple plate )
- torque figure
- kw / hp
- how you drive it ( track it here and there / often or street it only )
My gearbox is in great condition when i was running 234kw on the 26 and redline oil but now ive got a RB30 with HKS2530's expecting close to 600hp, probably a decent torque level too with the ported head, ported manifolds , ported rear housings etc...
Going to wakefield soon.. Will probably blow the gearbox there... hopefully not till the end of the day haha.... can only hope !
I've got a single plate 6 button brass button now without a spun centre which is gna be a bastard... Lol... told jim berry i wanted something nice and driveable but he gave me that ... oh well..
How did yours go ?
https://www.sau.com.au/forums/topic/442016-gtr-gearbox-question/
Hey guys,
- torque figure
- kw / hp
How did yours go ?
This will be interesting I have one of the jim berry clutches too just built I think its solid centre to and im getting my 26/30 built as we speak
Subscribed
  • Like 1
Guys, what's your turbo selection?
Precision 7175, come on Paul give me the bad news. :)
On the other hand, give me directions for a good box that should hold up......
Edited by GTRPSI
Good luck :D.
As for the box, you'll start to realise there is a "gap" in the market. OS set, maybe, but a few guys on here have busted them with sub 500 kw atw, let alone the 5 million you're gonna make with that thing! Whatever the direction, it's $$$ and lots of it! The 1-4 PPG helical dog set is prob the cheapest way out.
Ive been lurking in that PPG thread of yours a few times now, seems to be the right way going by discussions.
At the moment saving pennies and dimes, and trying to convince my son to do the change before the engine goes in, while he still has a box to work on before he blows it.
Watching.
I have an rb30det in a patrol, same gearbox (internally), weighs in at 2200kg on 35" tires, so has massive drive train load. (and 240,000km old)
My only upgrade was the cusion button sprung center clutch- 2100kg pressure plate.
Don't have a power figures yet, but guesstimate around 200-210kw atw?
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
