You guessed it – baby on the way................
I’m the original owner of this black 1992 GTR since it arrived at Turismo Motorsports in Adelaide back in the day. I bought this in 2001 and have owned it for the past 13 years and have rebuild most of the running gear in that time. It is in very good condition for a model this age.
The motor has since been rebuilt with forged CP pistons, ARP rod and stud bolts, R33 crank (new), oil restrictors in the head, Mines rocker cover baffles, tomei sump baffle kit, N1 oil and water pumps, sard 700cc injectors, trust heavy duty timing belt, power fc & boost controller, Z32 afms, nismo fuel pump, tomei dump and front pipes, trust 517z turbos, Blitz 100mm intercooler, bigger radiator (can’t remember exact size) and oil cooler kit in the front bumper and Duncan’s attessa torque controller. As well as fitted with Tomei Poncams, Tomei adjustable cam wheels also fitted at the time of rebuild.
I have driven less than 10 000km since the rebuild.
Also has lightened flywheel and heavy duty clutch, hi flow exhaust (can’t remember exact model) – very legal/quiet but unrestricted.
All work done by Boostworz and all of the above would be able to be verified by Shaun.
R33 Brembo brakes all round, Bilstein shockers, King springs and braided lines fitted by Manta Racing
Panasonic MP3 player head unit installed with a double sub woofer in the boot – came from Japan like that!
Wheels are RAYS GRAM LIGHTS 17x9 +22, with new Federal tyres, 255,40x17 all round
Car has been dynoed at just under 330kW on 98 octane, clean, well maintained there is literally nothing to spend, just drive and enjoy, never raced, dragged or even driven in anger.
Currently only listed here, hopefully someone on SAU will pick this up.
Any questions and dyno can be sent to anyone interested - please ask here or PM me for my phone number, car can be viewed by appointment at Crafers,
Thanks
Jason
  • 4 months later...
Jase it was a pleasure to meet you today and buy your car from you. 750ks covered on the way home and it was brilliant. Car performed perfectly whether at 40khr or stretching its legs.
Passed 13 traffic police cars in the first 400 k's. Fun busters ;-) I may have gone out to look at it a few times since getting her home already. Beautiful car in great condition. Just what I was looking for. I'll take very good care of her mate. Thankyou.
  • Like 1
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
