Turbos, turbos make things interesting.
But seriously, engine dress up on a N/A car is pretty much rice, no point. Just clean it up, make them rockers nice and shiny to increase resale value, resulting in more cash for when you do get to choo choo :)
....keep the bonnet shut. Done!
But seriously maybe clean your engine bay, maybe some new black hoses make it look as new as possible.
I'd rather see a nice clean engine bay then some riced up colourful, bling-bling engine bay.
Other then that go with post #2 bitches love jigsaw puzzles
  • Like 1
haha brilliant ideas :P
yeah i've been looking into some new hoses and maybe an alloy intake pipe.
think painting the rocker covers is a waste?
thanks dudes
Use genuine rubber hoses, the silicone ones are very cheap and are fine for intercooler and intake piping but often get pin hole leaks when you use them for coolant.
When I had my engine out the block was acid dipped then bored 40thou, honed and decked then sprayed black. All new welsh plugs and every hose in the engine bay with a new genuine part (coolant, fuel, vac and blow by), had the sump (acid dipped), head rebuilt and cleaned and the intake manifold.
Then replaced all the bolts and studs on the engine with new genuine ones, new coil pack cover, polished the rocker covers like a mirror (paint flakes or chips of easy) and added an alloy radiator and extractors heat wrapped. I made it look good as new with the exception of the alloy parts, a pod filter and extractors.
That's as good as its going to get with a N/A
whoa that's awesome, please tell me you have pictures haha
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
