cobrAA Posted April 18, 2014 Share Posted April 18, 2014 Hello there,It appears the right CAS for BNR32 is the 23731- 08u00. However, I have in my hand a mitsubishi that look very quite similar to the one installed on my car but part number is 23731-02u11. ( which is stated good for 93 to 97)Anyone ran into this problem ?Thanks! Link to comment https://www.sau.com.au/forums/topic/442044-cas-2-different-mitsubishi-part-interchangeable/ Share on other sites More sharing options...
XKLABA Posted April 19, 2014 Share Posted April 19, 2014 Does it work in your car ? Link to comment https://www.sau.com.au/forums/topic/442044-cas-2-different-mitsubishi-part-interchangeable/#findComment-7261343 Share on other sites More sharing options...
89CAL Posted April 22, 2014 Share Posted April 22, 2014 Ive seen one with a solid plug in the middle and others with a rubber plug in the middle. Not sure if thats the different number? Link to comment https://www.sau.com.au/forums/topic/442044-cas-2-different-mitsubishi-part-interchangeable/#findComment-7263844 Share on other sites More sharing options...
GTRPSI Posted April 22, 2014 Share Posted April 22, 2014 I thought the rubber plug Mitsu ones were R34 GTR. Are the engagement ends the same? Link to comment https://www.sau.com.au/forums/topic/442044-cas-2-different-mitsubishi-part-interchangeable/#findComment-7263879 Share on other sites More sharing options...
R.3.2.G.T.R Posted April 23, 2014 Share Posted April 23, 2014 I thought the rubber plug Mitsu ones were R34 GTR. Are the engagement ends the same? R32 and early r33 cas are either hitachi or mitsi units (interchangeable), R34 and late model 33 (series 3 and neo?) use different cas with black plastic on the outside (Not compatible due to different engagement)need to use r34 gtr cams with r34 cas Link to comment https://www.sau.com.au/forums/topic/442044-cas-2-different-mitsubishi-part-interchangeable/#findComment-7264383 Share on other sites More sharing options...
89CAL Posted April 23, 2014 Share Posted April 23, 2014 The Hitachi CAS' are the Neo ones, the mitsubishi ones are from earlier models Link to comment https://www.sau.com.au/forums/topic/442044-cas-2-different-mitsubishi-part-interchangeable/#findComment-7264684 Share on other sites More sharing options...
