Good Place To Get A Rwc, Will Bigger Turbos, Power Fc And Boost Controller Be A Rwc Issue?
Its been a while since ive had to get a rwc,
im located in brunswick but happy to travel for a reputable person,
im looking at an interstate car just have some queries, have been told that bigger turbos, power fc and boost controller maybe a rwc issue?
can anyone confirm this?
could anyone recomend a good rwc workshop?
thanks!
You won't get anyone to recommend a good workshop willing to look a blind eye at mods. It's a good way for them to lose their RWC license.
PM me if you like. ;)
Technically it shouldn't
Roadworthy certs are to filter out cars with serious defects from being sold to other people such as rust, worn seatbelts, tyres, low brake pads etc. on the RWC there are basic sections for tyres, brake effectiveness, windscreen, etc. I doubt you'd find a section for aftermarket mods or non std items.
On my last RWC it failed (the car I brought) due to tyres and worn steering wheel. Mind you that was a shitty ba wagon.
You should be fine
i retract my previous comment
turns out there is a "modifications" section on the roadworthy slip as shown below. i honestly forgot about this section.
ill be going through similar challenges for my new car
has a few shiny things in the engine bay that wont affect "roadworthyness" but make it look shiny - so not sure if they will consider it a "modification"
the best i could find on the vicroads site was about modifications such as complete engine swaps, changes to gross/net vehicle weight and seating capacity changes
here's the vicroads section on "modifications" and the main categories
Change of body
Heavy vehicles
Light vehicles
Change of colour
Change of engine
Change to seating capacity
LPG & CNG conversions
Changes to recorded Gross Vehicle Mass (GVM)
No mention of aftermarket performance mods etc so you should be ok
will let you know how I go with my new car and its RWC (has a few mods)
  • 3 years later...
Didn't want to create a new thread so I've revived this one.
What's the current status on getting a RWC for a car with:
- ECU (PowerFC)
- Electronic Boost Controller
- Aftermarket steering wheel with no airbag (original had an airbag)
- Fixed back seat (car has been converted to 2 seater)
I think everything else on my car is fine.  I'd just like to understand these issues before trying to fix them.
Probably won't pass with any of those if rwc tester is 100% by the book.
ECU is hidden so shouldn't be a problem. Remove hand controller if fitted.
Remove/hide boost controller
You can try your luck with the steering wheel and seats and see if they pick on them.
  • Like 1
I'm confident deleting the airbag is instant defect UNLESS the model of car was offered with non-airbag version.
eg series 1 R33 (I believe)
Not sure about fixed back seat, if the car is registered as a 4 seater, then there needs to be 4 seatbelts, regardless of whether its been "converted" unless Vicroads have approved the change.
  • Like 1
  • 2 months later...
May sound like a silly question but the tachometer in my r33 gtst manual cluster doesn't work anymore however the speedo and other guages work fine. Would this definitely not pass a roadworthy? Need to get one to clear a defect (too low).
The tachometer might just be dry joints, if you can solder or a mate can, it's potentially a very easy fix as that's a common issue with them. Generally it stops and starts working intermittently at first with changes in temperature and then will eventually just outright stop working if that is the issue. If it was working perfectly and then just stopped without bring intermittent it's probably more serious.
  • Like 1
Thanks TiTAN, i already resoldered all the connections but to no avail, the tacho is mostly dead then has random spasms every now and then. The odometer has now stopped working aswell. Will just get a replacement cluster when i can.
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
