Ok need some words of advice here,
I currently own a r34 gtt, which has a 3 inch front pipe, hi flow cat and 3 inch apexi cat back exhaust. I am not happy with the 3 inch exhaust as it is off a gtr and sits very low and scrapes over any little bump in the road.
So anyway I have a 3.5 inch fujitsubo cat back exhaust sitting in the garage, it does not bolt up to the cat because the flange is too big for it. I am looking to upgrade the turbo to a hypergear high flow, bigger pump and injectors etc..
Should I:
  1. Fit the 3.5 inch cat back to the 3 inch system already on the car, will this effect sound, performance by much?
  2. Remove the 3 inch system fit the 3.5 inch cat back and have a 3.5 inch dump pipe, front pipe and hi flow cat made up/bought? Is a 3.5 inch system over kill for my setup?
Any serious advice is appreciated.
https://www.sau.com.au/forums/topic/442072-exhaust-question/
Cut and reweld the brackets holding the current 3" system so it sits higher, and exhaust shop could do this or if you have a welder you could do it yourself, alot cheaper and makes more sense than having to stuff around with flanges to attempt fitting a 3.5" cat back...
3" is plenty for the flow youll get out of a highflow turbo too
This is spot on
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
