I've got a few items for sale, all brand new with 1 exception, all located in Melbourne, and all prices excluding delivery.
Please don't waste my time with ridiculous offers - I believe these are priced fairly. First person with funds transferred gets the items.
Contact via PM or e-mail - shom(underscore)b(at)hotmailcom
Direct Dropbox image links included per item.
1) Genuine Apexi Power Intake universal pod filters - 8 of
- Universal Apex'i pod filter replacement elements - non-oiled, easy to clean with compressed air
- 500-A022 (black x 6) and 500-A032 (silver x 2)
- Superb balance between filtration and airflow - http://www.mikekemper.com/elantra/filters/
- Supported 550rwkW without any evident restriction or collapse
- Lifetime use provided they are cleaned with compressed air at regular intervals and the integrity of the material is sound - I checked every 10000km
- Bought in anticipation of long term use, but surplus to my needs
- These are backordered from Japan (I checked recently), and ship in largish boxes which adds to their unit cost
- I paid $110 each, but will sell them for $90 - no waiting!
https://dl.dropboxusercontent.com/u/85877652/Power%20Intake%201.jpg
https://dl.dropboxusercontent.com/u/85877652/Power%20Intake%202.jpg
2) 2 x Genuine Metal Cat 2.5" cat converters
- http://www.horsepowerinabox.com/HPIAB2/prod522.htm
- Probably the best metal substrate catalytic converters out there- US EPA and CARB legal (I've taken pictures of the stamps and the installation paperwork that comes with them)
- 200 cells per inch, 590-odd cfm worth of flow
- Markedly more resistant to blockage than standard substrate cats, legal, and a flow rate close to that of a straight pipe, so the best of both worlds!
- Cost me a small fortune - almost $900 for the pair, selling for $250 each/ $500 for the pair
https://dl.dropboxusercontent.com/u/85877652/Metal%20Cat%201.jpg
https://dl.dropboxusercontent.com/u/85877652/Metal%20Cat%202.jpg
https://dl.dropboxusercontent.com/u/85877652/Metal%20Cat%203.jpg
3) Aeromotive 340 and 2 x OEM USDM TT Supra Denso fuel pumps
- All pumps brand new, boxed, unopened
- Flow testing of these pumps - http://realstreetperformance.com/Fuel-Pump-Comparison-Test.html?search=store+pages
- Aeromotive "Stealth" 340L/hr pump - tiny, silent and I have had one reliably running in my car for the last 4 years
- Supplied enough fuel for 550rwkW, and continues to supply enough for 475rwkW on a daily basis!
- Tested to provide enough fuel for 785hp at 65psi fuel pressure with the least current draw of comparable pumps
- Surplus to my needs - I always purchase 1 extra pump in case of failure, but I recently removed and inspected my current Aeromotive pump and it's pristine
- Denso USDM Supra TT pumps x 2 - nothing to say about these that hasn't already been said; quiet, rock solid OEM reliability, excellent flow (300Lhr at 14V, 632hp at 65psi fuel pressure) with reliable increases when the voltage supplied is increased (http://www.stealth316.com/2-fuelpumpguide.htm)
- Cost me $195 (Aeromotive) and $240 (per Denso pump) delivered - selling for $170 (Aeromotive) and $200 (each Denso)
https://dl.dropboxusercontent.com/u/85877652/Aeromotive%20pump.jpg
https://dl.dropboxusercontent.com/u/85877652/Denso%20pumps%202.jpg
https://dl.dropboxusercontent.com/u/85877652/Denso%20pumps.jpg
Just to update, there are in fact 3 Denso pumps BNIB.
Also, in case it was unclear, I have 8 of the Apex'i filters, and the selling price is per filter.
Obviously I would be happy to negotiate pricing for someone purchasing multiple units - this applies to the filters and the Denso pumps.
Thanks.
Edited by shombre
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
