Here i have for sale my pride and joy which i have owned for the last 5 years, This R32 would be perfect for anyone after that quick street able GTR they have always wanted. The car is currently making 310kw ATW on 98 pump fuel at 20 psi on a conservative tune for reliability ,with a E85 Tune the car made 375kw on 20 psi. With more boost and E85 this car will push over 400kw easy . Selling it due to having a work vehicle now and not much opportunity to drive the GTR anymore.
Below is a list of the major modifications on the car
R34 GTR N1 Engine Rebuilt 2000kms ago(Cleaned,Bored&honed and decked block/head)
CP Pitsons 8.5:1 with upgraded wrist pins
BC H-Beam Conrods
Regrund Crankshaft with ACL race Bearings
Tomei oil pump
Tomei headgasket
High octane 9L sump
New gaskets through out
New timing belt kit with water pump
Koyo 53mm Radiator
4 inch think front mount intercooler
Oil drain from cyl head to sump
Reconditioned head With BC SGL valve springs
Tomei Type B drop in cams
1000cc injectors
WALBRO 450LPH E85 IN-TANK FUEL PUMP
High Mount Precision 6262 Ball bearing turbo with full 3 inch exhaust (stainless catback)
Haltech platinum pro computer with Zeitronix wideband sensor kit
Rebuilt front diff and LSD rear diff
Bc coilovers front and back
All suspension bushes change front and back about 1.5years ago
Rear adjustable camber arms
Hicas has been removed with a lock bar in place
Front and rear Cusco strut braces
New Reco front driveshafts
Nismo twin plate coppermix clutch
DBA slotted rotors all round with reco calipers and braided brake lines
Very Rare Mines Centre gauges and Mines speedo
Blitz turbo timer , Greddy electronic boost controller and blitz temp gauge
Pionner flip out screen with Alpine amp , Alpine type R subwoofer and upgraded speakers
Air con works perfect
Carbon Fibre bonnet
Spoiler delete (Holes have been welded up)
Volk GT-C rims 18 inch with toyo tyres with about 40% wear(near new)
As you can see i have only used the best available parts, This car is very quick on the street and the all round performance of the R32 GTR is unbelievable for a car produced in the late 80's, If you have an enquires do not hesitate to send me a message or give me call
photos and contact details can be seen here :http://www.carsales.com.au/private/de ... -AD-2733379/?Cr=0&sdmvc=1
https://www.sau.com.au/forums/topic/442132-r32-gtr-for-sale-precision-6262/
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
