take all the plugs back out again, and check them.
was the white part of the plug cracked? did you remove the old plug properly, sometimes if you have the socket on a bit of a angle it will crack the plug and bits will go inside the cyl then can get stuck in the valves and cause all sorts of issues.
always use BCPR7ES plugs gapped to .6 (if you got coil issues)
btw love the ghetto old school extra injector setup.
Yes the white part of the plug had snapped. I just replaced them all. I looked around but no one sold bcfr7es.. Only online but it would have taken too long to get to my house so I thought I'd go with the 6 rating plug instead.
to confirm if its head related your ment to put a tiny bit of oil in the spark plug hole before comp test, this will seal whats ment to be sealed and comp result will go up confirming issue with the head.
when i broke my 20 ( air leak past afm + over heating+ on limiter ) it was a much more louder and metallic sound
Go to Repco, they carry those plugs in 0.8mm gap, run them on my RB20
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
