Genuine Gizzmo MSIB-C v3 Electronic Boost Controller (53PSI)
QUICK SUMMARY
Gizzmo’s MSIBC has been on the street now for approximately 10 years and has the glory of being John Bradshaw’s choice on his 7.45sec 187mph GTST Skyline.
Albeit the best value controller anywhere, the MSIBC-V3 uses a genuine American MAC solenoid and a precision Motorola pressure sensor. All the critical hardware components are high precision and quality branded items.
In it’s initial design we purpose built an engine setup so we could fine tune the boost control on our hub dyno up to the advertised 3.5 bar; we ran it up to 53 psi to be exact (3.65bar). At that level we were getting fluctuations of +/- 0.3 psi on the test mule, so approx 1%.
This control software still resides at the heart of the MSIBC-V3 although everything around it has been improved. The processor is now 16bit instead of 8bit. Physically it is 80% smaller and 70% lighter (with bracket) than previous versions. Now, to make mounting easier, it has a mounting bracket, also we have now added a feature that allows you to quickly set up your boost, even in real time whilst on boost if you’re feeling a little crazy.
So like most of todays technology, the MSIBC-V3 is easier to use, lighter, smaller, more powerful than ever before yet still costs the same. We challenge you to find a better value boost controller anywhere in the world!
FEATURES
NEW for V3 Easy set Boost feature
NEW Reversible adjustable mounting bracket
NEW Tiny Profile (57mm x 26mm x 30mm)
NEW Weighs approx 40g with bracket
Remote Scramble/Memory Change (Yellow wire to earth)
Simple 2 wire installation
Open and Closed loop boost control
Closed Loop Solenoid Supervisor
Operating Current < 0.5A
Reverse Battery Protection
6 Boost Memories
32mhz 16bit RISC Processor
Active Over Boost 5psi to 50psi
White 7 segment LED display
White backlit buttons
Real Time digital boost gauge
Pressure Display in PSI, BAR or KPA
Suits Internal or External Wastegates
Comes complete with High Performance MAC Solenoid & All Fittings
ONLY $290 incl. Delivery (Express)
BUY_BUTTON.gif $290 Delivered
  • 3 weeks later...
With more functionality then the eBoost Street and same MAC solenoid as the eBoost2 these have proven to be fantastic HP-4-ur-buck!
:yes::yes::yes:
  • 1 month later...
Same guys...
... Knock monitor set-up also available.
Introducing the K-Lite>
Gizzmo's K-Lite signifies a new evolution in engine protection. With 11 frequency & gain settings, 6 knock display levels, peak recall and housing 2 processors dedicated to protecting your investment, you know exactly how close (or over) the limit you are. The accuracy of the KMon in the size of a shift light.
  • 1 month later...
  • 2 months later...
  • 1 year later...
This is hand's down the best value for money electronic boost controller on the market today - Australian designed unit's.
Make use of the same USA solenoid as Turbosmart.
